Question about Panasonic NV-VZ18 Camcorder
My screen keeps turning off after about ten seconds
When i turn the camera onto VCR mode it comes up with a black screen with 0:00.00 and then it won't respond to any buttons, then after about 7-10 seconds it turns itself off. the battery is fully charged and i just way to see some childhood videos which are on the tape
hardrocko
  • 1476 Answers
SOURCE: Camera will not turn on
Remove the battery for about 30 minutes. This will reset the unit and if it is a software issue it should be OK. You can also try it on the AC adapter in case the battery connector is defective. If reset allows it to work on AC but not battery you have a problem with the DC input connector. If you are good with your hands, have jewelers screwdrivers, magnifying glasses, a steady hand and lots of patience as well as good soldering skills you can remove the cases and repair the input connector. If you are not confident about doing this you will need to seek the help of a reputable repair shop. Hopefully, removing the battery and resetting the unit will solve your problem. Good luck.
Posted on Jul 25, 2006
SOURCE: Camera just won't work!!!
HOW TO FIX panasonic 150x digital 20X MODEL NO. PV-D301D
Posted on Dec 12, 2007
SOURCE: Camera says "Push The Reset Button" Won't turn on
go to this site: http://www.fixya.com/support/p399886-panasonic_palmcorder_pv_gs15_mini_dv/manual-7042/page-60
I had the same problem, just read info on site tried another tape and problem solved. The tape was incompatable.
Posted on Dec 25, 2007
  • 221 Answers
SOURCE: power button broke
definitely a power supply problem. the power supply board is about $200 plus labor.
Posted on Nov 24, 2008
SOURCE: reSET BUTTON
The same happens from time to time with my panasonic NV-GS11 GC video camera and I have no idea what is causing it. But what I normally do is just turn it of wait 10 seconds and turn it on again. If it stil comes on try removing the tape and see if it is faulty.
Posted on Dec 14, 2008
Bizhub 751 c 3803
Sir/Mam,
Turn off the main both power switch one located inside the front door, second on the control panel, then wait ten seconds. then turn on main inside first. Then holding down the utility/counter button turn the sub power switch on. You must keep the utility button down The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit check. Have a qualified tech look at it. :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! Fire could occur that would ruin a perfectly good day!!!!
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
My canon gl2 lcd screen and viewfinder black
Same thing happened to me. No display, no menu, no S-video output while in camera mode, but in VCR mode all was OK. Turning power off and on did not help until I also disconnected the AC power adapter. BTW, Mr. Riggins did not read the question before he answered.
Nov 25, 2012 | Canon GL2 Mini DV Digital Camcorder
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Proscan vcr model psvr71 is in lock mode following directions in manual won't unlock it, is there some way to get it out of the lock mode other than what the manual tells me to do ?
I read the user's manual again. I misunderstood and held both on/off button and vcr1 button at the same time. I should only have been holding one of the buttons for ten seconds or untill the vcr responded=-=-=-=-=-DUH !
Nov 02, 2009 | Thomson Televison & Video
Wont turn on
www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
Jul 30, 2009 | RIM BlackBerry Pearl 8100
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
In camera mode only black screen is visible.
Hi-
Try to check the menu setting if there is an option to turn on/off the LCD screen of your camera when on the camera mode. Some cameras have options to turn LCD screen off.
Keep me posted... thanks!
Aug 02, 2008 | Canon Cameras
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
White LCD Screen
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
Dec 09, 2007 | Fuji FinePix F410 Digital Camera
JVC HR-S9500U
OK, found the problem. Another website had the same question on the HR-S9600U, the 9500's replacement:
http://www.cippico.com/bbs/viewtopic.php?p=528&sid=ce3dfc944e4539181195720b836021f4
I checked my vcr, and, sure enough, there was a sort of clicking sound coming from the drum area immediately before the unit would go into "Auto" mode. I removed the complete drum assembly, and tore into the little gearbox, and found the two black, plastic gears with inside pinions that drive the metal screws to change the video head position had each cracked and were slipping on the shafts. This caused the gearbox to bind up.
Using a jeweler's screwdriver, I roughed up the metal shaft and the inside of the gears where they slip onto the shafts, and glued them on using a two-part epoxy. I then re-assembled it all, sorta setting the screws about two turns after their contact with the base of the upper drum. Now, upon power-up, the drum adjusting motor toggles one direction, then the other, and the unit stays on. Playback seems OK.
So, there you go. Yay me....
Oct 19, 2006 | JVC HR-S9500 S-VHS VCR
Panasonic NV-VZ18 Camcorder Logo
27 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
