Question about Dishwashers
I do not know how to use my new bosch silentplus dishwasher
I want a shorter program than 3 1/2 hours ECO thAT it is set once you switch it on and there is a smell that I dont like I only used the dishwasher once and I did not like the results the dishes were not clean
  • Athanasia Stamatakis
    Athanasia Stamatakis Mar 18, 2014
    the manual is not user friendly I had dishwashers before for the last 20 years never have I encounter such a complicated mashine I want to go and choose the cycle and the time myself this mashine has everyting pre programed and the duration is far too long to use the Eco program is 3 1/2 hours long I think is far too long I want the same function for a shorter duration and the end result ( spotless) like my previous dishwasher and the smell were does it come from it is discusting. my disher were not clean and the odor was discusting why?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: 3 hour cycle - dishes not clean - bosch dishwasher
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jul 18, 2010
techbuster
  • 5081 Answers
SOURCE: my dishwasher leaves a film
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Posted on Jan 07, 2011
Taking six hours to wash dishes what is the problem, not first time having a dishwasher
Is that on all programs? We have a Fisher & Paykel which takes about 80 min on Normal progtam, but many hours on Eco. We think it is designed to trade off time to use less water and total heat on Eco programs.
So it may be normal. What is the make and model and someone here may know of it?
Jun 20, 2016 | Dishwashers
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
2 wks old on a eco wash and after 2 hours still running. is this right?
Hi!
Yes, it is OK, eco wash means less heating energy and less water, but in order to do the dishes clean, it requires more time.
Regards,
Bogdan
Aug 21, 2011 | Bosch Dishwashers
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
Ariston L63 dishwasher stopped mid cycle with water in base.
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Jun 16, 2009 | Ariston Technologies L63 Free-Standing...
Bosch 24 in SHU66C05UC/14
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 08, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
Ariston LL64 doesn't start
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
Dishwashers Logo
18 people viewed this question
Top Dishwashers Experts
