Question about Zebra Symbol MC3190G Wireless Portable Terminal
REGISTRY EXPORT TOOL
Hi, i need to set my time zone as permanent when the device is booting. Is there is any tool to export the current time zone in MC3190. please help me . Becaus my application will work depends upon the timezone
Tip
Yahoo Messenger Problems
Probably security zone settings of your computer.<br /> First Uninstall Yahoo Messenger.<br /> Run RegEdit then back up your registry. right-click on the computer icon and click export to back-up your registry, save it anywhere you want.<br /> <br /> Then go to HKEY_CURRENT_USER\Software\ find the yahoo folder then delete it. and go to HKEY_LOCAL_MACHINE\Software\ find the yahoo folder then delete it.<br /> <br /> Run search&gt;&gt;&gt;All files and folders Type YAHOO in "all or part of the file name:" lock in your local hardrive&gt;&gt;choose more advance option check the search for hidden files. Delete all files of yahoo.<br /> <br /> uninstall your internet explorer. go to RegEdit &gt;&gt;&gt; HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ then delete the zone folder. Then go to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ then delete the zone folder.<br /> <br /> Download Registry Cleaner to clean up your registry. Restart your computer.<br /> <br /> Download and install internet explorer after download go to&gt;&gt;&gt; internet option&gt;&gt;&gt;Security&gt;&gt;&gt; Reset all zone to default value or enable your activeX<br /> <br /> Download and install Yahoo Messenger.<br /> Run and Good Luck.<br /> <br />
on Nov 13, 2010 | Computers & Internet
Tip
Yahoo Messenger not showing messages Fix. wit regedit zone
Probably it is the ActiveX settings of your computer.
Then go to HKEY_CURRENT_USERSoftware find the yahoo folder then delete it. and go to HKEY_LOCAL_MACHINESoftware find the yahoo folder then delete it.
Run search>>>All files and folders Type YAHOO in "all or part of the file name:" lock in your local hardrive>>choose more advance option check the search for hidden files. Delete all files of yahoo.
uninstall your internet explorer. go to RegEdit >>> HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionInternet Settings then delete the zone folder. Then go to HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionInternet Settings then delete the zone folder.
Download and install internet explorer after download go to>>> internet option>>>Security>>> Reset all zone to default value or enable your activeX
Run and Good Luck.
Iam unable to view instant messagas from my yahoo messenger.
1. Exit Yahoo! Messenger by right-clicking the tray icon and selecting Exit.
2. Before you edit the registry, you are advised to make a backup:
a. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
b. Type regedit and click OK. This opens the "Registry Editor."
c. On the "File" menu, click Export.
d. In the "Export range" panel, click All, then save your registry as Backup.
3. In the "Registry Editor," browse down to following location in the registry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\
4. You should only see a list of numbers under Zones. If you see an unrecognizable character before zone 0, delete that particular key.
5. Close the Registry Editor.
6. Open up Yahoo! Messenger and try to send messages again.
Jul 19, 2010 | Yahoo Messenger
Sony vaio vgn-fs775p laptop real time clock not keeping time
Hi
thank you for your query
If the time is not keeping up then it would seem that you will need to change your CMOS battery, this is a small battery found on the motherboard responsible for clocking etc
The battery is cheap to purchase, however I do highly recommned the laptop be booked into a reputable PC shop for replacement as you will need to take the whole laptop apart to get the motherboard
I hope this has been helpful
Mar 09, 2010 | Sony VAIO VGN-FS790 Notebook
Configuring MC9090 default settings
Hi
When you set the wireless profile you set the SSID, WEP, IP etc. Which I'm sure you already know. Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 08, 2009 | Symbol MC9090 Barcode Scanner
Alow a scanner into the network
When you setup the wireless profile you set the SSID, WEP, IP etc. Which I'm sure you already know. Quite a few people forget the fact that they sometimes need to set a static IP if they do not have a DHCP server. Also if you set the WEP encryption keys incorrect the MC9090 will give you the green signal bar, but you can not get it onto the network, this has confused quite a few people in the past. Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key and thus details of the wireless profile are imported.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles. Has a lightly different registry key setting. The bonus about this is if you pull note the registry key file name you can then browse for the key using active sync and copy it to a host PC. You can then copy this key to any other device and cold boot and hey presto your wireless profile appears. You would of course need to change a static IP and export the profile again to overwrite the existing one. If you didn’t export again you would get duplicate IP’s on the network.
The last thing to check is the regulatory options; if you wireless profile is showing a yellow warning triangle this is usually the problem. From the wireless icon in the task bar, select options and then from the pull down select “Regulatory”. Un-tick 802.11d and select the correct country. Then from the pull down select export and export options, this will make them persist through an old boot.
TIP: Always take a not of terminals MAC address and match the serial numbers or specific ID’s. If you do ever get duplicate IP’s you can trace the offending device using the MAC address and the list you create.
helpdesk@biastechnology.com or TEL 01202 620955
Nov 27, 2009 | Symbol MC9090 Barcode Scanner
Problems opening links in Outlook 2003
The most common cause is a corrupt registry key in Internet Explorer. The registry key found at
HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
is either damaged or corrupt.
To fix it, try resetting Web settings in Internet Explorer. If this does not resolve the issue, set IE as
the default browser.
To Reset Web settings:
Internet Explorer 6
Start Internet Explorer 6.
On the Tools menu, click Internet Options.
Click the Programs tab, and then click the Reset Web Settings button.
Under Internet programs, verify that the correct e-mail program is selected.
Click to select the Internet Explorer should check to see whether it is the default browser check box.
Click Apply, and then click OK.
You may receive the following message when Internet Explorer starts:
Internet Explorer is not currently your default browser. Would you like to make it your default browser?
If you receive the message, click Yes.
Internet Explorer 7
Start Internet Explorer 7.
Click the Advanced tab, and then click Reset.
Click the Programs tab, and then click Set programs.
Click Set Default Programs.
Click to select Microsoft Outlook, and then click Set this program as default.
Click OK, and then close the Default Programs dialog box.
In the Internet Options dialog box, click the Programs tab, and then click Make default under Default web browser.
Click OK.
Back to the top
Export and import the registry key from another computer
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
Note Use this method only if the earlier instructions for each browser do not work to resolve this problem.
Export the registry key from another computer
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate the following registry key: HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
Click the command folder.
On the File or Registry menu (depending on your operating system), click Export.
Note the location of where the file will be saved. The registry file can be saved directly to the hard drive or floppy disk.
Type a unique file name, and then click Save.
Quit the Registry Editor.
Import the registry key
Copy the Exported registry key to the desktop on the problem computer.
Double-click the .reg file.
You receive the following message:
Are you sure you want to add the information in drive: location file was copied to\file name.reg to the registry?
Click Yes, and then click OK
Jul 27, 2009 | Microsoft Outlook 2003 for PC
When battery goes dead, does not save wireless LAN settings
PS Please stop informing people to phone manufactures tech support. Is that not what we are trying to bypass.
Jun 16, 2009 | Symbol MC9090-G RFID Handheld Barcode...
My xp does'nt save/write current/new settings/action
you have to go in BIOS,then BOOT OPTION,then arrange the boot order as i mention
first boot device:cd rom
second boot device:hdd(harddisk)
then press F10 enter
Apr 07, 2009 | Microsoft Windows XP Professional With...
Zebra Symbol MC3190G Wireless Portable Terminal Logo
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
