Question about Cell Phones
Internal application a viber voice message cant be recorded at this time. please make sure your microphone isn't being used by another application.
  • 1003 Answers
SOURCE: send voice memo
no thats factory set in phone software
Posted on Jan 15, 2008
SOURCE: DISK ERROR WHEN I TRY TO USE MP3
I had the same issue and just connected the device to my computer USB connection and performed a quick format on the drive and it now works. You will be warned that reformatting the drive will erase all the data, which will happen. But you can simply reload your music and be back in business... Rod
Posted on Apr 19, 2008
  • 13433 Answers
SOURCE: how to hear my voice through my usb microphone?
by default the playback of your voice is muted. next to your clock theres the sound speaker icon click on it, you should see microphone somewhere there, if you dont press settings from the toolbar and then properties
then on the playback make sure there is a X on microphone.
then click ok, now check is the microphone muted? unmute it and speak to the microphone you should hear your own voice played back instantly from the speakers.
Posted on Apr 28, 2008
nasirahmed
  • 282 Answers
SOURCE: nokia 7373
Now again disassembel your phone and put the mic. It will be ok.
Posted on May 17, 2008
double click on the volume icon on teh right hand bottom corner,& check whether the microphone option is muted or not
Posted on Jul 23, 2008
No audio devices are installed
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable
Feb 13, 2013 | Toshiba Satellite L355-S7902 Notebook
The recording sound can not detect any voice
Make sure you have the volume turned up on the microphone and make sure the microphone is not muted. Also go into your audio properties and make sure the voice recording and microphone is selected and you might be able to run a test from there also.
Mar 20, 2012 | eMachines Emachine D525
A4tech PK-7MA flexicam, the cam is working but yahoo messenger cannot detect the microphone cant able to make voice call
Go under the volume control in Windows and make sure that Windows is using the camera as the recording/input device and make sure the volume isn't set too low or muted.
Apr 27, 2011 | A4tech PK-7ma Flexi Webcam
If someone rings me, then i can hear him but he cant hear me. thats my problem
There is likely a problem with the microphone, test it by downloading/using a voice recorder application, if this works then you need to perform a master reset then a software update if that does not work. However if the voice recorder also doesn't work then you need to have the speaker replaced/repaired by the manufacturer.
Feb 02, 2011 | Cell Phones
I?m facing a problem with built-in microphone that its not working after i install XP.
Try going to the control panel,
  1. click on sound's and audio device's,
  2. in the sound's and audio device's propertie's box click the voice tab at the top,
  3. under voice recording check to see if the internal mic is checked in the voice recording, default device box,
  4. if it is click the volume box, a new box will appear that say's recording control,
  5. make sure the microphone has a check in the box,
  6. under microphone click the advanced tab,
  7. in the advanced tab make sure the microphone boost has a check in the box,
  8. go back to the sound's and audio device's propertie's box under the voice tab,
  9. at the bottom of the box under voice click on test hardware,
  10. on some built in microphone's you have to talk into the area where the mic is located on the laptop.
  11. if it does'nt help try using the device manager to resolve the sound issue's, check to see if the device is enabled, if it is use the troubleshooting tab to see if the device has a conflict, if it's working properly it will say this device is working properly, or try using the update driver tab.
Apr 16, 2009 | HP Compaq Presario CQ50-210US Notebook
Can not record a clear voice message
The internal microphone might be failing. If you haven't already tried….call into the answering and recording the greeting that way.
If that's been tried and doesn't work, there isn't much more that can be done as modern electronic devices are not designed to be user fixable.
You might be able to find a used 1725 or 1726 for sale on eBay.
Nov 29, 2008 | AT&T 1725 Answering Machine
How increase my mic volume
a) to hell with calling india, they are as dumb as bush is.
b) click start > accessories > entertainment > volume controls. when the volume controls open, click on file (drop down menu) then select recording, then click ok. when the recording volume controls come up. select microphone as the default recording device, and make sure the mute box is not checked. slide the volume control slider most of the way up.
c) if you are using yahoo's call-out, run the audio wizard in yahoo messenger before making call.
d) plug your microphone into other 3.5 mm jacks on computer, and use window's sound recorder to see if the computer is picking up audio through the mic.
e) make sure your microphone's mute switch is not turned on (if applicable).
Jun 23, 2008 | Acer Aspire 5610 Notebook
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Voice and Recorder not working!!!! Please DO help!!!! :D
take it technician u need to change its microphone. because it dropped on floor so damage has done with microphone, so take it to technician
Feb 07, 2008 | Sony Ericsson T610
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
