Question about TOA Electronics A912MK2 Amplifier
4-8 Ohm Output Overpowered?
This amp is 120w rms correct? how come this amp almost fried a 1200w subwoofer (using 4-8 ohm channels). im kinda confused
  • TOA Electronics Master
  • 5,047 Answers
You weren't by chance connecting a powered subwoofer to the standard speaker channels? Most powered subs require a dedicated output from the amp, otherwise you would be amplifying the signal twice over!
Posted on Mar 23, 2014
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Dec 09, 2007 | Audio Players & Recorders
What would be the best size amp to purchase for two audiobahn aw1200 subwoofers and two pioneer 4-way 6"x9"?
First, I would purchase the amp based on the subwoofers alone. Allow unit power to run the 6x9's unless you are planning a intricate setup. Things to think about when buying your amplifier. Always get an amp that offers an RMS output of 25-30% greater than the combined RMS output of your subs. Also, the stability of the amp to handle ohms loads (1, 2, or 4 ohm stable). If you have two dual 4 ohm subs you can get a 2 channel 2 ohms stable amp, or a monoblock 1 ohm stable amp. This will get you the most power and sound for your buck. There are so many amplifiers out there at different price levels, it's really up to you. Hope this helps.
Sep 03, 2011 | AudioBahn AW1200 Car Subwoofer
I have a 1200watt amp that's only providing 300watt output with 8ohm Behringer B212 speakers. Is there a resolution and what would it be?
I'd need to know more about the amp, but don't forget, amps are rated as their max power...
So lets take a 300W/channel stereo amp at 8 ohms.
Ok, it's stereo, so there's 600W
But the amp is capable of 4 ohm loads...well, now you can deliver 600W/channel, for a total of 1200W
In this scenario, your amp is doing exactly what it was designed to do with those speakers.
If you wanted to get the full 1200W out of the amp, you'd have to hook up 2 more speakers in parallel to the ones already there. This drops the impedance to 4 ohms per channel = 600W / channel.
Yes, the power is split among the apeakers...300W per speaker into 4 speakers = 1200W
so any way you look at it, there's your 1200W
Feb 27, 2011 | Behringer B212 600watt, 2-Way PA Speaker
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    I have 2 15'' CVRs and a 1200w amp
    1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
    Mar 05, 2010 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
    I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
    Hi mate very nice amp you got there here is the specs for it
    Model: MA Audio HK401SX
    Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
    1 x 1800W RMS @ 0.5 Ohm Mono
    1 x 1200W RMS @ 1 Ohm Mono
    1 x 650W RMS @ 2 Ohm Mono
    1 x 500W RMS @ 4 Ohm Mono
    Fully Unregulated MOSFET Power Supply
    2 Ohm Stable @ Mono
    1 Ohm Stable @ Mono
    0.5 Ohm Stable @ Mono
    if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
    Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
    NOT SURE WHAT OHMS SUB I NEED!
    if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
    Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
    2 ohm speakers wont work on a lanzar max pro 4000 watt
    The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
    Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
    I found this amp and I can't seem to figure out what the wattage is?
    You are probably aware on how to use these output figures, but I'll write a quick explanation on the specifications for future readers anyways :)
    The concpet CC-452 amplifier has the following power output specifications:
    Calculated at 14.5 volts DC;
    At 4 ohms per channel - 45 watts x 2 (RMS)
    At 2 ohms per channel - 70 watts x 2 (RMS)
    At 4 ohms bridged - 150 watts x 1 (RMS)
    This means that your amplifier would provide 45 watts of power each for your front speakers, which are normally a 4 ohm load per side (45 watts for left, 45 watts for right), that's unless they are one of those exotic higher end brands (eg: Boston Z6s which are 3 ohms). Rarely, you will find speakers that are rated at 2 ohms per side, but in this instance the amplifier will provide 70 watts of power into each speaker. On your speaker specifications, you will find a value termed "nominal impedance" which will give you the ohm rating of the speakers being used..
    On the other hand, if you "bridge" both channels into a single channel (using a diagram often marked on the speaker terminals of the amp), you could then provide 150 watts into a subwoofer (providing it was a 4 ohm woofer).
    It's not recommended to use this amp bridged under 4 ohms..
    Some subwoofers may be lower than 4 ohms, and you will not be able to use this amplifier for these types of speakers without risking amplifier failure. Also, some subwoofers may have 2 seperate voice coils, and you will have to use both channels of the amplifier seperately (not bridged) in order to correctly connect this type of speaker for use.
    Oct 28, 2008 | Concept CC-452 Car Audio Amplifier
    TOA Electronics A912MK2 Amplifier Logo
    101 people viewed this question
    Top TOA Electronics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a TOA Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
