Question about Eaton Computers & Internet
Bypass abnormal alarm system - Eaton Computers & Internet
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
Bypass alarm 2000 ford tauras
Just unplug the wires from the system at the alarm itself. It' just plugs into the wiring harness. or cut the wire with a pair of dikes. Removing the fuse could disable something else also.
Oct 16, 2014 | Ford Taurus Cars & Trucks
UPS Bypass mode failure
it looks like you have a faulty static switch
Apr 11, 2014 | Eaton Powerware 9355 UPS System
My 1999 Nissan Pathfinder won't start. How do I bypass the security system?
you can not btpass the alarm. do not have the keyless entery. ?why do you think it is the alarm?
Dec 04, 2012 | 1997 Nissan Pathfinder
I have a prestige alarm system on my car. my car won't start
there may have been a starter kill relay wired up to this when the alarm was installed, contact the busness that installed it to find out if one was put in and how to bypass it
Feb 15, 2010 | Prestige 2 Button Remote Security System...
Need bypass factory alarm in 99 dodge
well thats an interesting idea but by bypassing the alarm your car will not usualy start it is a safety feature that is built in to all chrysler autos it will disable the starter coil door locks windows and half the electrical systm as a safety feature and anti theft feature
Dec 30, 2009 | 1998 Dodge Caravan
How to take ups in manual bypass mode.
You definitely want to follow the manual procedure to avoid a possible load loss:
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9390.aspx?cx=3
9.1.4 Transfer from Normal to Bypass Mode
To transfer the critical load to Bypass mode:
C A U T I O N
In Bypass mode, the critical load is not protected from commercial power interruptions and abnormalities.
1. Press the CONTROLS pushbutton on the main menu bar. The System Controls
screen appears.
2. Press the BYPASS pushbutton on the System Controls menu bar.
The UPS transfers to Bypass mode and the critical load is immediately supplied
by the bypass source. If the bypass source is not available, the power processor
remains on and an alarm sounds.
3. The UPS is now operating in Bypass mode and the BYPASS status indicator is
illuminated.
The power module (PM) status indicates READY. The system is now on bypass
and the UPS power processor remains on.
At this point, you can operate an external bypass switch to get to maintenance bypass if needed.
Oct 14, 2009 | Eaton PW9390 UPS System
Alarm bypass. alarm system faulty
This had been done many times before.... But it is VERY involved and you HAVE to know what your doing. To bypass the little "chip" in the key, you have to know its resistance value in ohms, then you get a resistor of the exact same value and put it in-line in the wire that reads the chip in the ignition. Then you have tricked the system into thinking that the right key is always there. Like I said you have to know what wire it is, what kind of resistor, and what value to put in. However the payoff is no more expensive keys....keys without the chip will now start the car, sience you have tricked the passkey system into thinking the key has the chip in it.
Dec 29, 2008 | 1989 Porsche 944
Computers & Internet Logo
Top Eaton Computers & Internet Experts
Lawrence Oravetz
Danny Kuhlmann
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
