Question about Epson Stylus C46 InkJet Printer
My printer doesnt operate but the green and ed light keeps on blinking. Trouble shooter said that parts inside of my printer are at the end of its service life
  • Epson Master
  • 511 Answers
You need to reset waste ink counter. UseSSC or Adjusment program. You can find at indoreset.blogspot.com.
Posted on Jun 14, 2009
When the security light keeps bli.nking,it will not start. I have had a computer and instrument panel circuit board installed,still nojoy!
this car has what we call a VAT's key security system. the most common problem with this system is that the resistor that is in the key looses it's resistance value and the security system no longer accepts it. as a locksmith I run into this very often and the fix is very simple but needs to be done by a locksmith or a mechanic that knows what they are doing.
the fix requires the teardown of the steering column and fitting ( hard wire ) of a resistor with the correct value directly to the ignition switch itself,, this basically bypasses the key security part of the system and from that point on you will be able to use just a regular ignition key ( flat key NONE VAT's key ) which will save you a lot of money in time when getting copies made, ( regular keys cost about $2.75 -- VAT's keys cost around $29.95 per key ).
seek out a local automotive locksmith or mechanic and tell him what you would like to have done and for about 85 dollars this fix can be done ( the cost of the resistor is about 5 dollars ).
this will solve your problem.
c...
Jan 04, 2011 | 1998 Oldsmobile Achieva
Epson stylus c45
most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
Jul 07, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Hp deskjet 3550 problem
my hp deskjet 3550 doesnt doesnt work it green light only keeps on blinking and no response from at all.. please help me tanx
Jun 24, 2008 | HP DeskJet 3550 InkJet Printer
Epson stylus c45 (Problem)
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
for sale very cheaply on E-Bay.
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
656 hp deskjet does not print
please replace the catriges with new orginal before replacing please clean the catrige inner part with cloth+water then replace new orginal one and then on.
please check the drivers is installed or not
start-setting- control panel down-printer and faxes
check printer drivers is there are not
and then please check it is in ready mode or in pause mode
it should be in ready mode
please give first single page and what you wish
Jan 01, 2008 | HP DeskJet 656c InkJet Printer
Epson stylus c45
you need to download the resetter program the counter will have reached its limit and needs to be reset, it is fairly simple.
Dec 15, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
