Question about BenQ Computers & Internet
Lcd monitor ground - BenQ Computers & Internet
    New Friend:
  • 60 Answers
Your monitor has a built in ground incorperated in the power supply.If the power cord doesn't make a complete circuit when tested with an ohm meter you have a faulty power cord.
Posted on Mar 18, 2014
Dell lcd monitor e178wfp rev a00
wrap a magnet around the cable or some tin-foil.
May 07, 2013 | Computers & Internet
Toshiba Satelite 105 4134 Major Resolution Problems
Sounds like your screen is going bad. It's either the screen or the video card inside of the computer, but most likely it's the lcd screen. Try connecting an external monitor to the laptop. You can Borrow a monitor from a neighbor, friend, relative or co-worker to connect to the laptop.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays correctly that proves your video card is ok and your lcd screen is bad. If the external monitor displays the same as your lcd screen then your video card has a problem. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 23, 2012 | Computers & Internet
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
Schemas cable VGA monit. Philips 107
1)-red
2)--green
3)--blue
4)--ground
5)--ground
6)--red(ground)
7)--green(ground)
8)--blue(ground)
9)--+5v from vga card
10)--stand by
11)--synchronus ground
12)--serial data
13)--Hsync
14)--Vsync
15)--serial clock
Mar 28, 2010 | Fujitsu Siemens 38B1 (White) 15" LCD...
Power ok no display
Tilt the screen so that light strikes it at an angle
If you look carefully at the screen can you see an image in the background.
If you can then the inverter for the backlight or the backlight itself has failed
No image is the LCD
Cheaper to buy another monitor !!!
May 23, 2009 | Dell E173FP 17" LCD Monitor
Static interference on LCD monitor
BUY A CHOKE AT THE COMPUTER STORE AND PUT ONE ON EACH END OF THE MONITOR CONEECTION AND ONE ON THE INPUT ON THE MONITOR THAT PLUGS IN COMPUTER SYSTEM, IF THERE IS ONE THAN YOU WILL HAVE TO GROUND THE MONITOR,
CHECK THE POWER OUTLET TO SEE IF IT PROPERLY GROUNDED, SOME ONE MAY OF ADDED HOT WIRE TO THE GROUNDING POLLS.
THIS DEVICE PLUGS INTO THE HALL OUTLET AND LETS YOU KNOW IF IT IS PROPERLY GROUNDED OR NOT GROUNDED.
THAT CAN VOID A WARRENTY ALL TOGETHER
ROD
Feb 05, 2009 | Computers & Internet
Acer al1916b high pitched noise when on standby.
Sounds like you could have an open ground? Also might check the wiring to see if you have a faulty connection in VGA cable or power supply cable
Jul 24, 2008 | Acer AL1916B 19" LCD Monitor
10.4 inch headrest lcd monitors
MOST OF ALL VIDEO OUTPUTS AR NOT STRONG I SUGGEST
ADD A VIDEO AMPLIFIER
Mar 18, 2008 | Car Audio & Video
Computers & Internet Logo
19 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
