Question about RTO NuWave Technologies Twister Blender
Sealing lid gaskets.
The two rubber lid gaskets fell off the lid. How do I return them correctly?
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Apr 02, 2015 | Krups 572 Power Xtreme VI Work Top Blender
Gasket melting
Awesome...
Try AMAZON FOR THESE parts...
((amazon be cool... dogs drool & cats rule)).
4X Sealing Gasket Rubber Ring Replacement Seals For Ninja Juicer Blender...
Jan 28, 2014 | NINJA Blenders
Owners manual for oster 2 speed blender model 4125
2 3
IMPORTANT SAFEGUARDS
When using electrical appliances, basic safety precautions should be followed,
including the following:
READ ALL INSTRUCTIONS BEFORE USE
• Unplug cord from outlet when not in use or before cleaning.
• To protect against risk of electrical shock, do not immerse the cord,
plug or motor base in water other liquids.
• Do not let cord hang over edge of table or counter or touch hot surfaces.
• Never leave appliance unattended when in use.
• Close supervision is necessary when used near children.
• Avoid contact with moving parts. Keep hands and utensils out of jar
while blending to prevent personal injury or damage to the blender.
A rubber spatula may be used only when the blender is not running.
• The blade is sharp. Handle with care.
• Always put the lid on the jar before operating the blender.
• Do not operate any appliance with a damaged cord or plug or after
the appliance malfunctions or is dropped or damaged in any manner.
Return the appliance to the nearest Authorized Sunbeam Appliance Service
center for examination, repair or electrical or mechanical adjustment.
• Do not use outdoors or for commercial purposes; this appliance is for
household use only.
• Use this appliance for its intended use as described in this manual.
• When blending hot liquids, remove center piece of two-piece cover.
• To reduce the risk of injury, never place cutter-assembly blades on base
without jar properly attached.
• Always operate on a flat surface.
• Unplug the blender when it is not in use, before taking off or putting
on parts and before cleaning.
• The use of attachments, not made by manufacturer, including canning
or ordinary jar and processing assembly parts, is not recommended
by Sunbeam Products, Inc. and may cause risk of injury to persons.
THIS PRODUCT IS FOR HOUSEHOLD USE ONLY
The maximum rating marked on the product is based on the attachment
that draws the greatest load. Other attachments may draw less power.
P
OWER CORD INSTRUCTIONS
Please follow the instructions below to ensure the safe use of the power cord.
• This appliance is equipped with a polarized plug. This type of plug has one
blade that is wider than the other. This plug will fit in a polarized outlet only
one way. This is a safety feature intended to help reduce the risk of electrical
shock. If you are unable to insert the plug into the outlet, contact a qualified
electrician to replace the obsolete outlet. Do not attempt to defeat the safety
purpose of the polarized plug by modifying the plug in any way.
• You may use an extension cord, if necessary, but be certain to follow
these guidelines:
- The marked electrical rating of the extension cord must be at least
120/127 Volt, 60 Hz, 10A.
- The extension must be arranged so that it will not drape over the
countertop or tabletop, will not be within the reach of children
and will not be tripped over.
• Do not pull, twist, or otherwise abuse the power cord.
SAVE THESE INSTRUCTIONS
Sep 03, 2012 | Oster Blenders
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the...
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Mar 15, 2011 | GE Blenders
Rubber seal is moldy. Can we buy a replacement anywhere?
Is this your product, Back to Basics Smoothie Maker Elite, Part Number: SE2000B
http://www.everythingkitchens.com/back-to-basics-smoothie-SEC-Elite.html
This took awhile to find but you are looking for Gasket/seal U12-72.
It can be ordered here:
http://www.abtecparts.com/Back_to_Basics_blender_gaskets.htm
Feb 01, 2011 | Back to Basics Smoothie Elite Work Top...
Leaking from the bottom of the glass container through the screw
Check the rubber gasket for damage or hardening and also for chipped glass on the sealing surface. Make sure the ring is not cracked causing loss of compression of the seal.
Also check that the leak is NOT at the shaft seal. Replacement parts should be readily available,
Nov 08, 2009 | Oster 4093-8 Osterizer Classic Blender...
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
RTO NuWave Technologies Twister Blender Logo
Top RTO Blenders Experts
eyecam
Ross Keen
Are you a RTO Blender Expert? Answer questions, earn points and help others
