Question about Smeg Washing Machines
Smeg s850 e5 wont spin out completely - Smeg Washing Machines
E5 smeg dishwasher
Water inlet solenoid valve faulty. Check this is voltage to valve when water should be flowing. Replace valve if there is voltage present.
Jun 04, 2014 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg sca130p. Interlock wont release after running through pyrolytic cycle. Tried running through cycle again but still wont open hours after cycle completed.
Cut the power to it completely, so if its on a breaker, press the test button on that breaker. Wait 3 minutes and put power back on. Has it cleared the problem?
Dec 21, 2013 | Ovens
Power button will not power up DSI614
There is probably a swich on the door latch that is bad or out of alinment which wont allow it to start if not latched completly,that is what I have found on some.
Nov 29, 2013 | Smeg Dishwashers
WHAT DOES "E5" error code means? I've got a KELVINATOR KTD600MD T/DRYER
water not been filled quick enough have you made sure the water is turn on fully and check the filter they get clogged up
Sep 12, 2013 | Smeg WDI12 Front Load Washer / Dryer
Have an S850 7.5kg top load washer. It is cutting out before or during spin cycle so washing is remaining very wet.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | Smeg Washing Machines
My smeg dishwasher is saying e5 what is the problem how can it be fixed
This means there is no water loading into the machine. Most common cause is a faulty water inlet valve.
You can test the power to the valve with a voltmeter. If there is power to the valves, then valves are bad. If no power to the valves, then there could be a problem with the selector switch or control board
Nov 10, 2010 | Smeg DWI614 Built-in Dishwasher
SAMSUNG S850 WONT TURN ON AND LENS IS STUCK IN OPEN POSITION
I had the same problem, Turn it on and wiggle the lens and it will become unstuck. Well thats what my problem was and that what fixed it. Good luck
Apr 05, 2009 | Samsung S850 Digital Camera
Smeg WM 16 AAA WASHING MACHINE
Try turning power off, unscrewing the back panel of the machine and removing, reaching inside and giving the wheel which looks like a waterwheel (has 'fans') a couple of turns. This is the pump and sometimes small particles jam the wheel. Turn the power back on and if still in mid-cycle should resume and finish.
Apr 12, 2008 | Smeg WM16AAA Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
