Micro sd card how to connect in pc - Computers & Internet
    New Friend:
  • 40 Answers
Try to locate slot for Micro SD.
YOU CAN USE ALL IN ONE CARD READER AND CONNECT IT USB PORT OR HUB
Posted on Mar 19, 2014
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
How can i scan my micro sd card with the help of compu
IT is very simple to scan a micro sd card by pc:
1. First way---Insert your card in your mobile and connect it with usb cable to pc and when detected by your pc, open My computer and there you will find a removable drive named as your memory card select it and right click cursor and select scan option when an Antivirus is present in your then only.
2.Use card reader, insert your sd card into a card reader and and through it connect to the pc and scan it
thanks for using fixya.
Aug 19, 2011 | Nokia 7373 Cellular Phone
My computer is not acknowledging the micro sd card in HTC phone
Check if your micro sd card is properly inserted in your htc phone.Go to the pc connections in your phone and set them to mass storage mode to access your sd card.
Mar 21, 2011 | Computers & Internet
How to save data to a micro sd memory card
connect your micro sd card into your phone then connect pc cable via phone and pc...an option appears on your phone select storage device...from their your pc will read from your micro sd card....
Oct 26, 2009 | LG Vu CU920 Cellular Phone
How do you insert micro sd card into the moddle
you can only insert card in to pc if theres a card reader in front most are sd only so you will hafto buy sd to micro sd adaptor cost 5 to 10 dollars `then you put micro sd in to sd card then into pc hope this helps
Oct 17, 2009 | Dell Dimension 1100 PC Desktop
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
Need to reformat micro-sd card in up stage phone
to reformat micro sd card in your phone
go to menu>my stuff>select removable disc or memeory card then select options>format
>>or you can reformat the micro sd card using your pc
>>connect the sd card to the memeory card reader then connect it to the memory card adapter
>>go to my computer then select removable disc then right click then select format
Feb 28, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Feb 17, 2008 | Garmin eTrex Vista GPS Receiver
Computers & Internet Logo
David Payne
David Payne
