Question about Magic Chef MCD1611B Microwave Oven
How to change light bulb in magic chef microwave mcd1611b
Need to know how to change microwave light bulb in magic chef mcd1611b
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
SOURCE: Magic Chef mco153ubf
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Posted on Feb 17, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Magic Chef Microwave Model MCO160S .
You can download that manual here.
Posted on Nov 27, 2008
SOURCE: Replace light bulb in Magic Chef MCD1611
Remove cover and look for light. Special torx is required to loosen screws.
Posted on Feb 21, 2009
How do you install light bulb on mcw1611 magic chef??
I'm not finding a Magic Chef model MCW1611, but I do see they have models like MCM1611B and MCM1611ST. Maybe it's one of those?
Either way, I would suggest checking your owner's manual to see if it mentions bulb changes. If for some reason you don't have yours, you should be able to download it or a similar one here. https://mcappliance.com/manuals
If the manual doesn't cover bulb changes, then you would need to remove the outer cover to get to the bulb, usually located on the right side near the magnetron.
Feel free to contact me for further info.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | Magic Microwave Ovens
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
How to replace interior light?
more than likely the outer cabinet will need to be removed. also, some microwaves do not have a simple screw-in bulb; instead use a bulb/socket assembly...just for fyi.
Jun 15, 2011 | Magic Chef MCD1611B Microwave Oven
How do i change ligh bulb magic chef mcd11e3b
Unfortunately I do not believe that the light bulb is able to be replaced. I would go here http://mcappliance.com/emailus.asp?Inquiry=parts and send them a question regarding it.
Best,
Bob
Mar 05, 2010 | Magic Chef MCD1110ST Microwave Oven
Feb 19, 2009 | Magic Chef MCD1611 Microwave Oven
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
I need installation instructions for magic chef model # MCO153UQ
Contact page http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 20, 2008 | Microwave Ovens
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCD1611B Microwave Oven Logo
160 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
