Question about Samsung HT-TX72 Theater System
How to reformat imuz tx72 - Samsung HT-TX72 Theater System
Bass treble on Samsung ht-tx72
Follow the link to the instruction manual. It is a pdf file so give it time to load. https://content.abt.com/documents/27920/HTTX75_om.pdf
Jul 20, 2016 | Samsung HT-TX72 Theater System
My Samsung HT-TX72 doesn't read the DVD's
Sounds like to optical pickup (laser) has gone bad. Unfortunately on this model Samsung never made just the pickup available for replacement, they always made you replace the entire changer. The last few times I've tried to find this part for replacement I haven't been able to locate one.
Mar 17, 2013 | Televison & Video
Cant get sound through speakers when watchin tv. only sound when watching a dvd
You need to cable from your TV audio out to aux in on the HT-TX72. here's a link to the manual.
You'll find what you need on pgs 23- 24. good luck.
http://downloadcenter.samsung.com/content/UM/201104/20110420100926545/20070405083933984_X70_TX75T_SEA%5B1%5D.pdf
Sep 12, 2011 | Samsung HT-TX72 Theater System
Remote control does not work for samsung ht-tx72 theatre system
the batt are stil ok enough Voltage?
your IR led is not interupted?
dipswitch are adjusted?
Feb 13, 2010 | Samsung HT-TX72 Theater System
My samsung ht-tx72
have you tried manuals.com?, not sure if they might have it, but they can find it for you
Oct 03, 2009 | Samsung HT-TX72 Theater System
UNIT WON'T TURN ON.
These are also used in microwave ovens so most hardware stores will have them on hand.
Buy two; if the first one blows, don't install the second until you check back here; this will mean you will need some further investigation. Fuses do blow because of metal fatigue (expanding and contracting with on/off cycles) but if the second one blows, the fuse is protecting against larger problems such as a failed output module.
Aug 25, 2009 | Samsung HT-TX72 Theater System
SAMSUNG DVD HOME THEATRE SYSTEM HT-TX72
I have no audio. I hooked it up to another TV and same issue.
May 28, 2009 | Samsung HT-TX72 Theater System
How do I hook up a ps2 so it will play in the surround sound for a samsung ht tx72
Your HT is only capable of inputting an external audio signal, either via analog RCA (red/white) or via an digital optical cable. The video of your PS2 will then be connected directly to the TV.
Feb 01, 2009 | Samsung HT-TX72 Theater System
Samsung HT-TX72 Home theater system - Disk Error
Try updating your firmware... samsung.com Or have you tried that?
Dec 05, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Samsung HT-TX72 Theater System Logo
26 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
