Question about Panasonic GigaRange KX-TG2432 Cordless Phone
Screen has black vertical lines
If I take battery out and replace it back in it shows normal but then reverts to those lines.. is it the battery needing replacement?
  • Official Brand Answer
  • 350 Answers
We regret to inform you it appears the telephone has an internal issue that a battery simply wouldn't change. We recommend you use the Panasonic.com/repair address to locate an authorized service center in your area.
Posted on Mar 18, 2014
Vizio Model# E3D42OVX. Black vertical lines on start up except for top 2"s of screen.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 18, 2017 | Vizio Televison & Video
Tip
If Your screen shows a: white vertical line on a black screen or, a white...
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, carefully using your finger find the too hot transistor or, chip; or, use component coolant; spray the too hot component with a component cooler repower the TV, until the screen comes back to normal. To fix: apply white sylicone coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Garden
Tip
TV shows either: black screen with: white vertical or, horizontal line
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
After taking pictures on a full screen, suddenly my camera appears to be set showing a black frame below/above for horizontal, left/right for vertical. I can no longer return to the full screen... wh
You've apparently switched your camera to the widescreen mode. To switch to another mode, follow the instructions under "Changing the Recording Pixels (Image Size)" on page 65 of this manual.
Mar 23, 2013 | Canon PowerShot SD1200 IS / Digital IXUS...
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Tv will not pick up 720 and hold, reverts back to 480, why?
480/720/1080 is a function of the XBOX not the TV. The TV cannot change the resolution. The resolution indication that shows on the TV is only what it is recieving, not what it is showing, You need to check the XBox or whatever you are using.
The Green Line on the other hand is a defect and if the TV is in warranty you should make them fix it!!! That is unless this green line only appears with a single source....it should show ALL the time.
Jan 06, 2009 | JVC LT-42E488 Television
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Vertical Lines Display - Recovery shows setup not complete
As per my experience, the problem is not because of your Video Card/Driver. Such a problem arises due to faulty RAM. Change your RAM and enjoy computing.
Thanks
Sep 13, 2008 | Toshiba Computers & Internet
OMG HELP!!PLEASEEEEEEEE WIERD LINE SHOWING UP
plesw see your LCD settings or remove your screen wipe if and then fit it and restart
Oct 21, 2007 | Nintendo Wii Console
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
Panasonic GigaRange KX-TG2432 Cordless Phone Logo
59 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
