Question about Mordaunt Short 502THX Main / Stereo Speaker
I need to replace the woofer in mordaunt short 906i but have been having problms removing the front aluminium cover. I have removed the screws but it does not come out. any suggestions? Thanks
  • 757 Answers
I don't have the solution for you but I know someone who very likely does. You can message a user on the sound and vision forums by the name of irritateguy.
Posted on Jun 19, 2009
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
How do I replace the tweeter on Mordaunt Short Avant 906i speakers?
Hi - Just reading your problem with the 906's and removing the front cover to replace the tweeter. Did you ever solve the issue? because I tried today and I can't budge the silver cover once the screws have been removed. My email address is chris.clemons@btinternet.com if you can help - thanks
Feb 16, 2012 | Mordaunt Short 906 Rear Speaker
TESCO MTG04ss MICROWAVE HOW DO I CHANGE THE LIGHT BULB?
Unplug the unit from the mains. Remove the 4 screws at the rear holding the cover to the unit, and the 2 screws on the right hand side, then slide the cover backwards to release and remove. On the right hand side near the front there is an aluminium housing with a connector on the top. Bend the front flap back to reveal the bulb. You may want to remove the screw at the top of the housing to make access easier. The bulb is a 240v 20w screw fit. Mine had just vibrated loose, so only needed screwing back in. Once replaced, follow instructions in reverse, ensuring that lugs on the bottom of the cover locate into the unit correctly for a snug fit. Plug mains back in and open the door to check the light works.
Jun 04, 2011 | Ovens
Hi my name is Ben. I have a Mordaunt Short home theatre system which is probably 6 yo but has had very little use. On standby mode, the 309W sub started to make a buzzing sound with intermittent louder...
It can be repaired. A transistor shorted and possibly some resistors burned open as well. This is due to an overload causing the transistor to drive hard creating heat and eventually shorting out. The transistor needs to be isolated, removed, and replaced as well as the resistors.
Nov 12, 2010 | Mordaunt Short 309W Subwoofer
How to install Kirby g4 fan
It needs to be stripped completly down, if you are confident at doing this then here goes.
It has been a while for me so take your time and some of the steps may have to be completed slightly differently.
Isolate / unplug the machine from the mains
Remove the bag, handle and front roller assembly so you are left with a bare machine.
Remove the rear switch cover - 1 x screw.
remove the top aluminium cover 2 x screws at the back and 2 x screws at the front below the light.
You should now see the motor and tech drive.
Remove the tech drive, tech drive belt and rear wheels 4 x screws below the machine.
Remove the wiring to the motor noting the correct connections for putting back.
unscrew the motor 4 x screws inside (think) and two at the front below the fan aperature.
remove the motor and fan complete.
To remove the fan, note the hole through the fan shaft close to the belt position, this is for leverage when unscrewing the fan, hold the motor shaft, insert a small screw driver or punch through the shaft hole and unscrew to remove the fan.
Re-fit in reverse order.
Jun 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Mordaunt short ms409w subwoofer rear panel removal
You don't have to cut the speaker wires.
Under the foam wrapping is a connector - just unclip it!
May 17, 2009 | Audio Players & Recorders
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
Technics SU-X955 amplifier. which speakers ?
Helo you have to use speaker of the same wattage you have now chage crossover to get new clear digital soud
Feb 11, 2008 | Technics SUV500 2-Channel Amplifier
No Power - LED not lit.
Open up the back of your gale 3080 and check the 2 fuses situated near the transformer.They look like 2 silver cylindrical shapes.Check that they have not blown if they have the will cost you around £2 to replace.Better than the 50 quid you will pay when you take it to your hi fi dealer to open up the back of it.
Aug 12, 2006 | Mordaunt Short 309W Subwoofer
Mordaunt Short 502THX Main / Stereo Speaker Logo
311 people viewed this question
Top Mordaunt Short Audio Players & Recorders Experts
 Grubhead
Grubhead
Tom Chichester
Bill Boyd
Are you a Mordaunt Short Audio Player and Recorder Expert? Answer questions, earn points and help others
