Sewing Machines Logo
C
Caryn Rousseau Posted on Mar 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fly wheel won't turn - Husqvarna Viking 1
Jerry Zanzig
Level 2:
Scholar:
  • Husqvarna Expert 104 Answers
  • Posted on Apr 14, 2014
Jerry Zanzig
Husqvarna Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
26225
Points
129
If all you get is a "whirring" sound when you try to run the machine, the belt most likely has slipped off the pully. You need take off the rear cover to get at the belt. Get a service manual that shows the bottom and rear Torx screws that have to be removed if you plan on fixing it yourself. If the hand wheel won't turn manually (or is difficult to turn), take it to a professional.
My Elna 62C doesn't run. The light works but nothing happens when I press the pedal. Does that mean the motor is bad? Or is it electrical?
There is insufficient information. Does the needle move when you turn the hand wheel. If it doesn't, the fly wheel has been disengaged. (This lets you wind a bobbin. However, if the bobbin winder pin has been returned to the left position, the winder isn't engaged.) This is controlled by the knob in the center of the hand wheel. Hold the hand wheel with one hand and turn the knob towards the back of the sewing machine.
If the fly wheel is engaged, then the problem could be the motor or the pedal rheostat. You might try to find a new compatible foot control first, https://www.sewingpartsonline.com/elna-star-62-sewing-machine-parts.aspx?index=1 . The motor is no longer available.
I hope this helps.
The lever that takes needle up and down will not move even when I turn the fly wheel at the side of the machine which you use to manually move the needle
The small wheel on the side of the hand wheel may not be engaged. If it still doesn't work when tightened you may take the small wheel off. On the small wheel there is a small screw that needs to be loosened so the wheel can turn all of the way off. Inside is a round metal piece with ears on each side. Turn it over and reattach the handwheel. Now, it may work.
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
My Janome 10000 seems to have jammed the fly wheel won;t turn, There is nothing stuck in machine, needle is not bent
yes, it is possible. or a part inside the machine could be broken
it would be a good idea to have the machine checked.
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
1helpful
HI problem with Consew 199R-1A. Machine locked up. I just started sewing and it locked up. Needle is fine, fly wheel won't turn more then 1/4 back and forth
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
I've just bought a Pfaff 1471 and it has "locked-up"... the needle won't go up and down and the hand-wheel won't move. Help please! :)
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
1helpful
2answers
I purchased a Ingenuity Singer Sewing Machine The machine will not wind a bobbin. I put the bobbin on the winder and sometimes it won?t activate when I push it to the right and other times it when it does...
Sometimes it is a simple thing like a faulty bobbin, there is a very small piece of plastic that the winder has to catch and if it is worn or broken or just plain faulty then the bobbin will not turn
Husqvarva 610
This was posted to the sewing machine category. Resubmit in correct category for a solution
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
