Question about Ducane 30400040 Stainless Steel Grill
One burner is burning, the other keep popping
Sounds like the gas is surging and the burner will light and go out over and over
    Scholar:
  • 104 Answers
Clean the orifices and small holes with a needle or paper clip. Also clean each control valve by inserting pin into hole. Shake out any dust from the tubes. Use wire brush in some areas. Good luck!
Posted on Jun 14, 2009
Carrier Weathermaker 8000 Furnace Flame Surges on start up
The fuel is controlled by the gas valve, the amount of gas is controlled by the regulator, I would verify that the inlet gas pressure is within the limits of the gas valve/regulator. The surging is likely the fault of the regulator and could be as simple as a spec of something in the orifice that allows gas pressure on the top of the gas regulator diaphragm. With the surge there must be an accompanied change in gas pressure at the gas valve outlet to the burners, use a "U" bend manometer to verify as they are the most simple and accurate and react instantly with no "averaging" software to wonder about.
Mar 16, 2017 | Carrier Heating & Cooling
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Burner does not light
The burner is not level ,or you need to adjust the air flow on the end of the burner.
Dec 08, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burner won't light on both sides of burned
The burner is lighting back to the injector on the gas control. 2 things burner out of postion or burner is blocked needs cleaning, you can remove this and clean with air line or small bottle brush.
May 20, 2012 | Grilling
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Dec 08, 2009 | GE Cooktops
Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Apr 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Ducane 30400040 Stainless Steel Grill Logo
475 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
