Question about 2SToner HP Laserjet Pro M1213nf Printer Toner - 6800 Page Yield
Scan images get blur - 2SToner HP Laserjet Pro M1213nf Printer Toner - 6800 Page Yield
When scanning and copying get lines
clean the scan glass,it's usually a .5 to1 inch strip of glass that the paper runs over while it is scanned and it probably has white out or something similar on it
Nov 06, 2013 | Canon Pixma Mg6120 Wireless Inkjet Photo...
Blurred pictures when scanned
If the blurring is slight, it could need a deep cleaning of the glass on both sides and/or mirror assembly. A tech would probably need to do this as it requires tools. If it's severe, it could be the mirrors or the image sensor itself. Again, I'd have a tech assess the issue.
Feb 03, 2011 | Konica Minolta PRINTING - Bizhub-250...
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
Why I am unable to send scanned messages by email succussfully, they are not readable by the recipient. I can scan and copy and send successfully, as an email attachment, but the recipient says the print...
hi, do check ur scanner settings. It is advicable to save the scaned image as a JPEG and then u can easily mail it. Do set the are the scanner is goin to scan perfectly. and see to u do not interupt he scan before u get the image on ur computer. If the problem persists do post again.
Jul 08, 2009 | Office Equipment & Supplies
Copy result is blur and I see the acceleration of paper too fast
When you say Blur? Is it a scattering of toner or is the whole image blurred or out of focus? You may have a problem with the lens HP or a problem with the scanning mirrors. Do you get a error code? Is the blur like toner strikes down the page? Check you corona wires and look for any small pieces of paper that maybe lodged in or around the drum unit. You may want to give a little more info. on the exact problem, to narrow down the cause
Dec 27, 2008 | Canon NP 6050 Copier
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
Blurred image on panasonic tc21p50r
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 09, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Blur image
try turning on the flash when capturing photos or if you dont want to , use a tripod
Sep 27, 2007 | HP Photosmart E317 Digital Camera
2SToner HP Laserjet Pro M1213nf Printer Toner - 6800 Page Yield Logo
23 people viewed this question
Top 2SToner Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 2SToner Office Equipment and Supply Expert? Answer questions, earn points and help others
