Question about Fisher and Paykel Dishwashers
Screeching sound dry cycle - Fisher and Paykel Dishwashers
My Kenmore 800 series gas dryer makes a very loud screeching sound when I start a drying cycle it can last up to 15 minutes what do I need to do
The loud screeching noise is either the belt pulley or one of the 2 wheels that support the drum. There's quite a bit of disassembly to reach them.
Aug 11, 2017 | Kenmore Dryers
WBSR3140GWW
If you screeching sound continues threw out cycle you main bearing is probably bad. I would get a different washer.
Feb 12, 2014 | General Electric WBSR3140GWW Top Load...
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
Big Thunk when Frigidarie Front Loading washing machine started the final spin cycle, then at the end of the cycle soft screeching sound when drum is moving back and forth, any thoughts? amshap50@gmai
does not sound good. if you can remove a cover on front bottom or on the back you may find a broken shock, or counter weight, either would need replacing before running again
Jan 08, 2012 | Washing Machines
When the dryer is running it sometimes makes a screeching sound momentarily on and off during the dryer cycle. Some cycles it does not make the sound at all. Is something going bad? It doesn't seem to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
May 02, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Handset leftout in rain. Now just screeches. Have been drying it out for 10 days now but still screeching.
Once water works it's way into an electronic device the damage is done, drying it out will not help most times because the internal components are already damaged.
Jun 23, 2010 | Uniden Cordless Phone
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Dishwashers Logo
11 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
