Question about Bosch Saws
Blade orbit selector lever broken - Bosch Saws
3 Suggested Answers
suzukiracing
  • 200 Answers
SOURCE: Blades disengaged while cutting Blade lever has
A new belt might be the way to go
Posted on Jul 19, 2010
  • 6468 Answers
SOURCE: blade broken off in quick change tiger saw chuck
use a pair of tweezer to pull it out or a magnit
Posted on Aug 22, 2012
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 | Bosch Saws
I am having trouble inserting the blade properly
You press the lever forward all the way, insert the blade, and release. If the holder is getting worn it can be replaced as one complete assembly. Here is the user manual link. It shows how to use the holder.
Skil 9225 manual
The part number for the holder assembly is 2610938752. It is less then $10 and is held on with an allen screw so it's easy to change.
Jul 15, 2012 | Skil 9225-01 9.5 Amp Orbital Reciprocating...
There are three dails on the 1581vs jig saw drill one is for the speed whats the other 2 for
The numbered wheel on the top handle is for speed control. The sliding (ratcheted) lever on the side near the blade is for controlling the forward motion - the blade can either go straight up and down or follow a slight orbit on the downward cutting cycle. The third dial is on the bottom and is used to adjust the angle of the blade w.r.t. the surface of the wood being cut.
Dec 26, 2011 | Saws
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
Blade keeps falling out when jig saw is started?
ther could be an old peice of a broken blade stuck in the collar were you insert new blade
Oct 07, 2010 | Ridgid 26638 Saw R3121 Orbital Jigsaw
Blade wont tighten
Here are some directions on installing the blade to ensure the proper procedure has been followed when installing.
  1. Set the blade orbit selector lever to position III.
  2. Fit the supplied screwdriver into the top plunger hole and loosen the internal blade securing screw about 3 to 4 turns counterclockwise.
  3. Insert the blade into blade plunger at a 90° angle to the cutting direction. With a slight upward pressure, turn the blade teeth forward (direction of cut) and guide the back of the blade into the groove in the center of blade roller guide.
  4. Pull gently down on the blade to seat the blade tabs in the plunger.
  5. With the blade in the proper position, securely tighten the blade screw by turning the screwdriver clockwise.
I hope this helps. Please rate on how helpful the answer was. Good Luck and have a great weekend.
Apr 03, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
My Makita BJV180 jigsaw will not do elliptical cutting even though I turn the lever to the elliptical cut position.
this saw has 3 orbital settings and one straight line setting .. in orbital mode the blade moves forward slightly on the up stroke and back on the down stroke .. it may be difficult to see and may not be pronounced without a load ...
Nov 12, 2009 | Makita BJV180 18V Lxt Lithium Ion Cordless...
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
Oct 20, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Saws Logo
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
