Question about Pinnacle Dazzle Video Creator Platinum (230100037) Video Capture
Blank Recording Screen
I have the same problem! I had also set it up with the splitters and the video signal from the PS3 was getting through to my PC but, it would only show a black screen and not what my PS3 is showing on my tv.
I've tried connecting my PS3 directly without the splitters to the Dazzle but it still comes up with a black screen.
Also, I've tried the same thing with my Wii & Xbox 360 and I come up with the same results =(
Help with this issue would be appreciated~ C=
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Dazzle Platinum not capturing
That distribution amplifer may not be picked up by the Dazzle. The recommended way to use it is to plug the output specifically what you are capturing into the Dazzle and not to split the signal through wires or through a splitter. It may have trouble locking in on the signal since the amplification in the capture device is weak. It's also tough to get support from Pinnacle Systems having it hooked up that way.
Most of the Dazzle capture devices have amplifiers in them which could be causing the problem as well. It is capturing 3 seconds of the video and cutting it off as a safety feature to prevent something from blowing out. Typically happens on the audio feed if it is peaking in the audio meter.
Posted on Sep 23, 2008
I had the exact same problem with version 11.1 and was able to resolve it by going to the pinnacle websaight and uploading the latest drivers.
Posted on Dec 27, 2008
Bubbabear64
  • 2794 Answers
SOURCE: dazzle platnium
There is no guarantee this is going to work right because you have to split the video signal and the audio lines to do it. Using an RCA Y cable you need to split the Yellow Video output line so that one line goes into the tv and the other goes into the dazzle. Same thing with the red and white audio lines. By splitting it, it will make the signal weak causing the tv display to produce a poor picture quality as well as the dazzle. You will have to give it a shot and see if that doesn't happen.
Posted on Dec 28, 2008
SOURCE: Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Posted on Oct 09, 2010
My Insignia DVD/VCR will play VHS tapes, but does not record on them when I put a blank in and it shows recording on the VCR, but when I rewind and playback, just get blank sometimes wavy nothing and snow!...
First thing to check is does the video actually get a TV signal to record? When you set the recording going is the channel viewable?
Next thing to do is clean all the video heads, this will include the erase head! If you still can't get it to record and the VCR does pick up a signal to record, then there will be an electronic fault that is causing the no record signal.
Aug 20, 2013 | Insignia Televison & Video
Help with insignia 24 inch flat screen? the av channel will not show the channel where i can play my ps3?at?
It sounds like yoru PS3 has stopped handshaking with your tv. It can happen. It's possible your brother disrupted the connection by unplugging the PS3 before it was shut down. You can try turning on the PS3 first, and then turning on the tv, or vice versa. If that doesn't work, you may need to invest in a cheap HDMI splitter, to plug the PS3 into, and then send the signal from the splitter to the TV. It has happened to me with a computer with the same hardware, once with an LED tv, and once with my surround sound receiver, completely out of the blue. You can try switching HDMI cables, sources, doing putting the tv into maintenance mode and resetting the software. If none of that works, your only option may be to use an HDMI splitter. I did extensive research and read numerous reviews before I settled on this model, due to many recommendations:
ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P & 3D ' Model: VHD-1X2MN3D
It's available on Amazon here:
Amazon com ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P 3D Model...
Just in case your HDMI cable was damaged when your brother unplugged it, go ahead and get yourself a decent HDMI cable. The Amazon HDMI cables work just fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jul 07, 2017 | Video Game Consoles & Games
When i turn my ps3 on i get no menu screen. tv says no signal and have a blank screen. as soon as i put a game in i get the picture on the tv
It sounds like your PS3 is putting out a resolution that your tv can't display when it is on the menu screen. The fix for this would be to press and hold the PS3 power button until you hear two beeps. This will default it to factory display settings and should set it to a resolution your TV can handle.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi to dvi blank screen no sound
Sometimes the PS3 automatically outputs it's video and audio signals in composite form. Try going back to your original composite cables and setting your system to output in HDMI. Those options would be under "Display Settings". Hope this helps!
Apr 13, 2011 | Samsung TX-P3264 32" TV
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
Nov 28, 2008 | Dell OptiPlex GX280 PC Desktop
Recording with easy cap 2.0
Re-Installing and removing does not remove everything from your REGISTRY. If you Install something then uninstall it you will be left with info in your registry therefore you r reintalling on same info vista has
Jul 09, 2008 | Ulead Videostudio 8 for PC
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Pinnacle Dazzle Video Creator Platinum (230100037) Video Capture Logo
65 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
