Defy daw350 not draining water - Washing Machines
I have a defy laundromaid. The machine doesn't reach the correct water level to start the washing cycle. However if I deselect wash and rinse options it does spin
good solid commercial unit 13 kg
could be a timer or control board fault
my best guess is
faulty water level sensor
Sep 20, 2016 | Washing Machines
What's your question?defy toploader drain motor keeps running as soon as power switched on!!
Hi some machines do this to empty any water that may have been sitting in the bottom of your washing machine and the water has went stagnant. It should stop when you start a new washing cycle if it does not you will have to have your machine looked as it would just be draining the water as it goes in.
Mar 18, 2016 | Washing Machines
Defy DDW 169 manual
My Defy DDW 169 Dishwasher won't go beyone draining on starting a wash cycle. What is the problem with the machine?
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
