Replaceing bearing on WM0535HW
L G front load
LG Front Load WM1815cs Makes loud noise when spinning. Inner tub is loose and seems to bounce making loud noise. Is this more than a bearing problem?
The outer tub and the bearing will need replacing as by replacing only the bearing will be a short lived repair as it will go the same way.
Aug 25, 2013 | LG WM1815CS Front Load Washer
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Dec 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do you replace drum bearings on a GE front load washer?
you can not. must replace entire rear of two piece drum that holds bearing. might not be worth time and costs!
Sep 28, 2010 | GE WSXH208A Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
Jul 04, 2010 | LG WM-0532HW Front Load Washer
Our neptune front-loader has become extremely loud during spin cycles, you almost need hearing protection, otherwise, it works great
Ball bearings have worn out. Replace as a set. Replace Water seals in the drum. Check the bearing shaft for any scrub marks. Check bearing housing. Fix new bearings now
Apr 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Where is the rear bearing located so i can grease it
The rear bearing is not accessible to grease. If you have a noisey spin that sounds like it is coming from the bearing it will have to be replaced. Most tub bearings on front loaders are preinstalled with the outer tub assembly. It is a major job to overhaul a front loading machine, requiring outer tub assembly, water seal kit and possibly tub gaskets. If not under a warranty it is not economical to repair.
Feb 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
Brown spots on clothes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Bearing fix
That job is for a very skilled person I would not take it on unless you are that person,by the way it comes in a kit TWO bearings and water shaft seal I would replace drum shaft as well Eamonn Ireland
Jun 12, 2008 | Candy CNW156 Front Load Washer / Dryer
How to replace the bearing on the drum of a fisher&paykel dryer ED56
top load dryer?? open top right end of drum remove toex screw and cover brass bearing slides out.. front load pry up top srews top inside front lift front out remove belt lift drum out bearing in back on rear wall
Apr 24, 2008 | Dryers
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
