Question about DeLonghi ESAM5500
POWER BUTTON NEED TO REMOVE FRONT COVER TO RE-ATTACH POWER (HAS BEEN PUSHED IN)
Hard drive door unscrewed and hard drive was hanging... Now this screen?
This is a network PXE boot screen. This is usually the last boot device it will try if it doesn't detect a HDD or cd/dvd drive with bootable media. You should be able to see a hard drive in bios, if not replce it and re-install your operating system.
Dec 25, 2012 | Computers & Internet
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
Sometimes when the power button is pushed the receiver does not come on. Sometimes it does come on. What could be causing this?
The power switch itself may have become intermittant...these switches are usually sealed and cannot be cleaned with contact cleaner...there also may be the possibility that the solder joints on the switch have become defective and need to be resoldered...you can remove the cover and look at the pc board that the power switch is on and see if you have good solder connections...a good solder connection will be shiny...a bad one will look as if it has a cracked ring look...if all else fails...you can simply replace the switch...I think Radio Shack carries them and they are not very expensive at all
Jan 18, 2011 | Onkyo TX-SR504 Receiver
Passenger side front window does not work.
Yea your right on that one, but to be sure test the regulator connector with a test light to be sure their is power getting to the motor. to remove the panel their will be a few screws around the panel and some snap clips on the back side of it, disconnect any connectors and be careful with the plastic clip for the door handle.
May 03, 2010 | 2005 Dodge Grand Caravan
Power
Simple, follow the steps;
  1. Unplug machine from wall
  2. Above power switch is 1 screw (remove)
  3. Remove paper tray
  4. Open and remove toner and drum
  5. Remove front door
  6. Lift cover and remove (when looking at machine from front back right side of cover has tab that needs to be unhooked)
  7. As you lift the cover up pull it to the left of the machine rotate out towards front of machine
  8. Power switch will snap in and out of its location on the metal frame. Just unplug and remove
Mar 30, 2009 | Sharp AR-153E Copier
Toshiba 1115 S103 Power button problem
there possibly is a spring between mainboard and the button, you may have to check if the button cover is simply held by the cover itself, remove the loose 'lid' of power button (if you still have it:same colour as laptop), attach it to the faceplate,and reassemble carefully the notebook.
good luck
Oct 21, 2008 | Toshiba Satellite 1115-S103 Notebook
Compaq deskpro
Use the following steps to open the case: WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer. CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
  3. Remove the screws that attach the side panel to the computer. Do not remove other screws, such as the power supply screws, that are also located on the back of the computer. c00371492.jpg
  4. Slide the left-side panel towards the rear of the PC to remove it. c00371493.gif
  5. If the front of the drive is blocked by an extra door that is part of the case, remove the front cover. You may have to remove the opposite side panel in order to access the front cover. Press in on the tabs that retain the front cover, there should three to four on each side of the cover and gently pull forward. It helps to have a friend help with this process. Carefully detach any cables that may also be attached to the front cover.
Mar 02, 2008 | Compaq Deskpro EN PC Desktop
Power button
This also helped me. Thanks
Oct 26, 2007 | Whirlpool LHW0050PQ Front Load Washer
DeLonghi ESAM5500 Logo
46 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
