Question about Panasonic DP-8060 MFP Copier/Scanner/Network Printer
Machine error e03 20
Plz tel me solution....??
Main Motor rotation 1. Drive Mechanism is defective.
2. Main Motor connector is disconnected.
3. Main Motor is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
8. LVPS is defectiv
Posted on Dec 23, 2014
We have Konica Minolta bizhub 164 copier machine its showing c6101 error code how to resolve that error plz tel me
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Sep 15, 2015 | Konica Minolta Office Equipment & Supplies
Tip
Hi! Plz help me I have satellite L305-S5908 I had deleted my windows vista 64...
NOTE: This Tip can be Hard, I recommend Advanced Users Only.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we'll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don't just use the default. I chose roughly 10gb by entering 10000 into the amount.
This step might be confusing, because we need to change the cd-rom drive that's invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it's already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn't the end of the world, but it's not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we'll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it's easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you'd like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can't do the next step until we reboot. (you can try, but it won't work)
So we've come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like "XP". It would be wise to name the C: drive to "Vista" at this point as well.
Now you'll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like "Hit Esc for boot menu" you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don't try and install onto your Vista partition! See how much cleaner it is now that we've labeled each partition distinctly?
We'll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we'll need to use the VistaBootPro utility to restore the Vista boot loader.
Download and install VistaBootPro from vistabootpro.org
During the install you'll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the "Windows Vista Bootloader" and then "All Drives" radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you'll only be able to boot into Vista, but we'll fix that. Instead of manually doing the work, we'll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the "Manage OS Entries" tab and then click in the textbox for Rename OS Entry, and name it something useful like "Windows XP" or "The Windows That Works"
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying "unable to find ntldr" when trying to boot XP, you'll need to do the following:
  • Find the hidden files ntldr and ntdetect.com in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can't find the files there, you can find them in the \i386\ folder on your XP install cd
You can share information between the drives, but I wouldn't recommend messing with the other operating system's partition too much… it might screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition "Data".
This works if you have the operation system "Windows Vista."
on Mar 28, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Barring password nokia c1-01
plz tel me nokia c101 ovi account opean plz plz tel me my e mail add is Rajabehera6000@gmail.com plz send
Oct 17, 2012 | Nokia C1-01 Dark Grey Unlocked/No Contract...
While Printing getting Communication Error E000 0000 plz tel me what the probelm
E000 means fusing unit error. Disassemble printer, check fuser heater and fuser sensors impedance, replace if necessary.
May 20, 2011 | Canon LASER SHOT LBP-2900 Printer
How to download themes for samsung c3222
help me for my samsung gt-c3222..everytime i play a games that i install it always show (java error no memory available)..help me to solve this problem..plssss.._11.jpeg
Jan 08, 2011 | Samsung GT-C3222
I have nokia china 2730 Bluetooth Error prob. plz tel me
you don't tell me that what kind of problem you facing so plz tell me in detail then i am able to tell a proper solution for your problem ok
Jan 03, 2011 | Nokia 2730 Cell Phone
How to unlock virgin vbling c3308
i have a virgin mobile vbling my a1000004d0479e its a medi no...plz tel me how 2 unlock my ph 2 any network...plz...
Nov 21, 2010 | Cell Phones
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
Mar 19, 2009 | Canon iR 2020i Laser Printer
The washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Dec 19, 2008 | Washing Machines
Canon Imagerunner 3570 error code
if u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
Jun 08, 2008 | Canon ImageRUNNER 3570 Copier/Printer
Panasonic DP-8060 MFP Copier/Scanner/Network Printer Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
