Question about IBM ThinkPad R40 2722 Notebook
I ran out of power on my laptop and when i turn it on it comes up with a lock and i don't know what to do
  • tombirchenou Jun 15, 2009
    the problem is though thanks for your reply but i don't know the password and i have already pressed the enter key but thanks anyway
  • 52 Answers
You might have put a password for your user account. If none, pressing Enter key resolves the issue.
Posted on Jun 14, 2009
I have a 2002 buick rendezvous I am have trouble with the fuel delivery it's not getting any power back to the fuel pump we had it started when we ran a wire to fuse box and ran it strait to fuel pump...
check the pressure regulator and wiring
some models use the regulator to notify the ECM that pressure has been reached so the ECM cuts off power to the pump relay until the pressure falls
Apr 13, 2017 | Cars & Trucks
Laptop backlight won't come on
Hi Fletcher,
Nowadays laptops come with an option to turn off the backlight to save power.
Since you have not included the model no of your laptop, i can't give specific info on how to turn on the backlight.
You can check the user guide of the laptop.
If that is not the case, the backlight board might have gone out and needs to replace it.
If you don't know how to do that, i would suggest you to contact a technician.
Sep 30, 2011 | Compaq Presario Notebook
Everytime I lock my computer,shut the lid or leave it untill it goes black, it will not come back on when I touch the mouse pad. However when I got this laptop it worked and when I opened the lid and...
Well by default Closing the Lid will cause computer to go to Sleep mode and you can't wake it up using mouse. However you need to press power button to wake it up.
But as you said it was working the way you explained then seems like Power settings on your computer are changed
To check the settings Got0 -Control panel and click on power Options Goto - Advanced and find the Lid open/close actions You can change it there If you don't want your computer to goto sleep mode with the lid close, you can simply disable it.
Hope this worrks
Jul 14, 2011 | Computers & Internet
I have an Acer Aspire 4730G that tends to heat up and then overheat when I do something that involves flash or something (or online games). A lot of the heat comes from the HDD, and I don't know where...
gpu + cpu also causes heat exhausting with a fan. dust sometime clogs this and overheats laptop. I have also tryed a laptop cooling pad, blows air on the bottom of laptop. my laptop still ran hot, due to poor design. not enough vents.
Jul 07, 2017 | Acer Computers & Internet
The caps lock and num lock don't come on when I power up my laptop.
Hi tnwright200, try this step:
Turn off the pc
remove the cables and battery on your laptop
Press and hold the power button.
reinsert the cables and battery on the laptop
Turn on the pc
Press Fn + Num Lock if Num Lock works
Press Fn + Caps Lock if Caps Lock works...
May 18, 2010 | Compaq Presario 700 470024-192 Notebook
Laptop doesnt boot
Let's try few steps ..
I would like you to try a POWER DRAIN .....
Remove the battery from your laptop,disconnect the AC adapter from your laptop and make sure no external device is connected to your laptop.
Now after disconnecting everything from your laptop press the power button for 20 to 30 seconds.
Completing this reconnect your battery and AC adapter and try to turn on your laptop.
Now chk the hardware first to make sure that the hardware is working fine.. ran the PSA test .. to do this turn off ur laptop and press the FN key and Power button in ur laptop at the same instance...it will take through some step let this test complete .. if it give any error msg note it down & please let me know if it doesn't give any error msg then you would need to reinstall the Operating system. Get your data backed up if you have somthing imp or you can also try parallel reinstallation.. If need further help please revert surly be glad to help.
Dec 17, 2009 | Dell Inspiron 1501 Notebook
Subs lock in place. Only direct current comes out of the speaker output
The amp has failed and will need to be repaired.
Let me know if you have any other questions.
Jul 18, 2008 | Rockford Fosgate Power 1500BD Car Audio...
Car doesn't start randomly. "security" light comes on and off. Have to leave key in "on" position for 10 min. to reprogram. Is there a fix?
you may have the same problem I ran into and have to turn your key on don't start the car yet wait about ten seconds with key on on position then turn it over should stop the security lite from coming on all the time and locking the fuel lines. let me know if this worked
A mechanic told me maybe if I replace the ignition that may be it setting off the security sensors? I don;t know I just wait ten seconds with the key on before I start it and as long as I do that it seems to work every time.
Jul 18, 2008 | 2002 Oldsmobile Alero
IBM ThinkPad R40 2722 Notebook Logo
51 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
