Question about Brother MFC J6710DW - Multifunction fax / copier / - MFC-J6710DW
When printing pictures it leaves fine white lines through them
All inks are full
2 Suggested Answers
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
I have a canon pixma mp 470 printer/scanner that i am using for the first time to print pictures. The first one printed out beautifully, but every picture since then has visible vertical lines in it. I...
rrenor,
You will find that the ink in the cartridge is low or almost out. If you haven't printed pictures for some time than the unit has still purged, which means to have sucked ink through the head, everytime you have turned it on. The long and short of this is that over time it has been emptying your cartridges. Nothing you can do about it, it is just the wayy these machines operate. Try checking the ink levels and if they are all full, leave the print head in park overnight and try again tomorrow, see what happens. If it is still giving you lines than it may need to have the print head replaced.
Don't do any more cleans now, you are just wasting your ink. Allow it to sit and you may find it will fix itself.
Gremlin11
Dec 11, 2008 | Office Equipment & Supplies
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
Canon i560 does not print pictures very well.
i have had the same problem with both black and colour, just take out your printhead and put it in a large mug and pour hot water not boiling into where the ink tanks sit and fill it just up to there leave it soak for a few mins and you will see the ink disolving into the water keep tipping out the water and doing this until not too much ink is saturating the water and all you are doing is unclogging the jets, must be hot water cold water doesnt work. After you think the jets are clear dry the printhead off with a hair dryer shove it back in, do a deep clean, maybe a couple, and it should print in all colours, if not repeat the above process and even let it soak overnight
Mar 25, 2008 | Canon BubbleJet i560 InkJet Printer
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Brother MFC J6710DW - Multifunction  fax / copier / - MFC-J6710DW Logo
13 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
