Question about Copystar Kyocera Fs-3140mfp fs-3140 Copier
Fs3140mfp printing dirty
Paper keeps creasing during printing. have moved guides out as far as they go
Creasing is usually caused by pare skewing so guides must be as tight as possible against the paper if it's still a problem you will need a new fuser a unit more than likely
Mar 12, 2015 | Kyocera FS-3140MFP Plus Black & White...
HOW DO YOU UPGRADE THE FIRMWARE OF A COPYSTAR FS3140MFP
http://www.helpowl.com/p/Kyocera/FS-3140MFP/Research/93849?search=fs-3140mfp%20engine%20firmware
Feb 11, 2015 | Copystar Fs-3140mfp Black & White...
Fs 3140 mfp error
Can you be more specific or provide error codes or messages?
Jul 04, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Error type :setting
if scanning to email it means you have one or more smtp settings wrong usally its the host address or authentication user and pass
if its to folder its either the ip of the computer is wrong or the login info is wrong
May 13, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Can you increase Fax Memory for FS3140MFP
Sorry, but that is the maximum and standard amount of fax memory available for this model.
Mar 03, 2014 | Kyocera FS3140MFP AllInOne Laser Printer
Printing from auto feed leaving lines down side of page
if you mean making a copy from the automatic document feeder check the slit glass (the thin narrow glass beside the big platen glass) for debris, white out, dirt, etc... a small dot on that glass will make a line on the copy.
Aug 20, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Turn on confirmation page
you need to turn that on at the control panel. you cannot toggle that option in command center rx
Jul 17, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Why does my copystar FS3140 scan slow
default the scan settings to grayscale or monchrome and drop the resolution to 300dpi or lower
Mar 06, 2013 | Kyocera Copystar FS3140MFP Copier
FS3140 memory full
this can occur if jobs hang due to printer error (empty toner, jam, etc...) if the printer usually prints normally but displays that message when faxes are being received then you may need to reset or replace the fax board and update the firmware. you could turn on hdd RAMDISK mode in the command center. You could also add additional RAM
Feb 19, 2013 | Kyocera FS3140MFP AllInOne Laser Printer
Canon Laser Class 720i
The drum is n/g or the optics are dirty. possible print roller.
Mar 19, 2008 | Office Equipment & Supplies
Copystar Kyocera Fs-3140mfp fs-3140 Copier Logo
32 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
