Question about Radio Communications
Pairing Ravon W65 to laptop - Radio Communications
Uhuru Bluetooth 3.0 pairing code default
try 0000 or 1234 what are you pairing to Macbook ?
Pairing Code will be for device pairing to Macbook
Sep 23, 2016 | Computers & Internet
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
Pairing smartphone to Ravon W65
  1. With the power on, press the small round button in the back of the unit just above the USB port (it has a little Bluetooth symbol over it) and the speaker will go into pairing mode.
  2. Turn on your Bluetooth on your phone or mobile device and let it scan for new devices. Once the speaker shows up just select it and it should pair.
Sep 12, 2013 | Radio Communications
Pairing code for dell wireless 370 bluetooth mini-card
Normally when pairing with any device, any pairing code can be applied (4 digits),and then when asked on the other system, the one applied on the first system, will be required to put in. In most of the cases, it is pre defined as 0000
Jul 06, 2012 | Computers & Internet
I dont know where to find pairing code
If you are connecting to Bluetooth headset, check the manual of Headset to find default pairing code.
If you are connecting to other mobile phone or laptop, you have to enter any pairing code you want and then enter the same pairing code to other mobile or laptop and both devices will be paired.
May 25, 2011 | Cell Phones
I've purchased a very clean, working White Model 65 but cannot find an instruction manual and need one if available for free. Can you help provide anything online? Thank you!
Hi
YOu can dowbnload a fee one from the singer site.
http://www.singerco.com/accessories/manuals.html
Just type in w65 and click on search.
On the next page click on the free download option at the top of the list.
Hope this helps!
Nov 14, 2010 | White Sewing 1788
Bluetooth Notebook 5000 Mouse will not connect. The green light comes on and then goes off. The bluetooth light on the laptop is on. Just changed the batteries. What to do?
You may just need to re-PAIR it. You need to press and hold the Pairing button until you get a solid blue light then it is in pairing mode, you can then discover it on your laptop and complete the pairing.
Jul 12, 2010 | Microsoft Bluetooth 5000 Mouse
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect my nokia BH-104 bluetooth handsfree to loptop
Oct 29, 2009 | Logitech Bluetooth Wireless Talking Kit...
Radio Communications Logo
46 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
