Question about Turbo Air HC09K20A-P3 Lodging Hybrid PTAC Air Conditioner with Cord and Plug - 230/208V, 9000 BTU
Hi, I recently bought and installed a hybrid unit and have been doing other electrical work so i have had to shut off the main power a few times. when i went to work in the shop today, i turned on the main power and even though the unit was off, the fan came on and the display read Lo. I didn't think anything of it and just turned it on and set it to heat. it read Lo all day and when i turned it off it did not stop, I thought to let it cycle instead of turning off the breaker but i came back hours later and it was still reading Lo and blowing heat even though it was off. Please help!
Hi! My LG Refrigerator gr-L247 after a power shortcut of around 3 hours it is not working.
I have read stories of some tv's doing the same thing after the power is cut off and you have to wait for a few hours for unit to "reset" itself. Contact LG for their feedback on this. Could be an issue with the electronics of unit.
Aug 22, 2016 | LG Refrigerators
DISPLAY SAYS "PF"
HI, there may have been a power surge that shut this unit down or, the junction box may be shorting the power sector. this will damage the main control in this case. i recommend shutting the power off by, pulling the unit plug from the wall socket or, shut the circuit breaker off. let the unit sit for 5 minutes without any power. this will reset the logic chip.
Power the unit back up after this 5 minute wait to see if the reset worked. if the PF is still present, this will confirm a main control fault. replace the control in this case.
**check the power cord junction point for worn connections.
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Sharper Image Hybrid GP. Unit powers on, goes to
The solution drgoff provided ( the guy that used to work for Sharper Image ) actually did the trick !!!! Super excited to have this unit working again , thanks drgoff
Jul 07, 2009 | Sharper Image Hybrid GP (SI724) Air...
ELGATO TV HYBRID PICTURE PROBLEM
You have to set your tv to just scan. Gets its all in. You can either do this through the menu or often a button on the remote. Good Luck
We Are Here To Help!!
Sep 27, 2017 | Elgato Systems EYETV HYBRID - 2 IN1 TV FOR...
B&D CMM1000 Mower
convert your mower to cmm1200. you needs parts 905058-81 to convert it.this to elliminate the circuit board & it's easy to install just follow the instruction. circuit board was on recall depend on the date code of the mower it is also no longer available.
good luck.
Jun 02, 2008 | Black & Decker 19" Electric Lawnhog...
Main problms with the Aura Green Line
1. 4 speed automatic - need I say more? It’s 2007 folks. Get with the program… 5 is an absolute minimum number of gears. 2. 28 MPG / 35 MPG - And this is a hybrid? GM - if you’re going to make a hybrid, then please, by all means, do it right. Look at the Prius or Civic Hybrid for inspiration. These are successful hybrids, that can run with the engine off. There is no need for a hybrid that cannot run on electric power alone - that defeats the purpose of the hybrid, and takes away one of it’s biggest benefits.
May 15, 2008 | 2007 Saturn Aura Green Line Sedan
No power
Hi Bret! Since this is a brand new printer, I would advise calling Lexmark. I'm afraid that you may void your warranty if you do much more at this point except for going back through the steps to make sure the duplexer was installed correctly.
1. Power off the printer and unplug the power cord from the wall outlet
2. Push the release button, and gently lower the front door.
3. Release the green tabs and lift up the image transfer belt.
4. Remove the cover over the duplex connector.
5, Remove the duplex option from the packaging. Carefully install the option into the printer, under the image transfer unit. NOTE: Make sure to line up the arrows on the duplex option with the arrows on the printer. Make sure the duplex option locks into position.
6. Lower the image transfer belt back into position. Make sure the belt locks into position.
7. Close the front cover.
8. Plug the printer back in, then power the printer on.
9. Try printing a few pages to confirm that the duplex option is securely installed. Then select the duplex option in the software and print a few double-sided pages to confirm that the duplex option is working.
The following link will take you to the instructions for enabling the duplex option in the software.
If the above does't work, I would strongly suggest contacting Lexmark for further help.
May 13, 2008 | Lexmark T630 Laser Printer
Digital TV Converter keeps shutting off
The DTA800 has a Power Saver feature that turns the unit off after 4 hours if it is idle (no volume or channel changes).
Press MENU button, press #5 (Setting/Configuration), press #3 (Power Saver) Select OFF to de-activate this feature (no Power Saver).
This is covered on page 11 of the DTA800 user manual.
Apr 25, 2008 | Televison & Video
Toshiba 20DL74...on/off
I had the same problem with mine and I finally figured out it was the power supply. I ordered a new generic replacement and I have'nt had a problem since other than a few noise lines in the lower channels and that might be because I didn't buy a Toshiba replacement which may have a filter in it. It has not shut off now for over a year.
Dec 26, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
My samsung dlp tv model hl-p5063 w cuts off multiple times while playing
Hi, I had the same problem on my Samsung.
I removed the rear cover and cleaned the cooling fans, there were (2), it has worked fine ever since.
Be careful of course working with electrical boards.
Dec 01, 2007 | Televison & Video
Turbo Air HC09K20A-P3 Lodging Hybrid PTAC Air Conditioner with Cord and Plug - 230/208V, 9000 BTU Logo
26 people viewed this question
Top Turbo Air Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Turbo Air Heating and Cooling Expert? Answer questions, earn points and help others
