Question about Sharp Televison & Video
Volume in Remote Control for Sharp Aquos LC-42A53M is not working
All other buttons in the Remote control are working EXCEPT for the volume. I have to control the volume from the TV itself. I tried unplugging the TV or changing the batteries of the remote but to no avail. Can somebody please help???
SOURCE: REMOTE CODE
i need the code for a sanyo!
Posted on Mar 06, 2008
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
  • 42 Answers
SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
Posted on Jan 04, 2009
  • 14 Answers
SOURCE: sky plus remote control - volume not working
you have to press home on your remote control, go to help and info, go to help with your remote control, a page then says if your remote control looks like the picture below and you can press yes or no but i always press yes and then you press ok to continue on the next page and on the next page there are loads of different tv makes and when you find yours you get the code that is next to it which is normally a 4 digit number, once you have the code you go back onto the normal tv, point the controls away from the tv and hold down the up volume button aswell as the mute button until the light on your remote flashes twice and then you enter your code and wait until it flashes twice again and hopefully it sould be working.
Posted on May 01, 2009
SOURCE: my sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Posted on Aug 05, 2009
Ga759wjsa, volume button dosen't work
First switch on a radio receiver which has AM ( medium wave band)
and if the remote controls batteries are good then ,,
tune the MW / AM to lowest frequecy and then start pressing buttons of remote control one by one. for each button pressed you will hear a sharp sound and the button you don't hear a sound in the radio speakers is the faulty one.Then open remote control ( that is if you know how to ,you may have to open few screws and also pry open some plastic latches .Best to take help from one of your friend who had already opened some remote control .)
clean contacts of control pad of remote control with Iso- propyl alcohol.also called as IP.use sergical cotton which will be clean enough.claen also PCB with IP.after drying for few minutes assemble it.take care not to tear the rubber control pads and do to use sharp instruments to clean any parts of the remote .
happy hunting
shekar
Jan 09, 2014 | Sharp GA759WJSA Remote Control...
Volume does not work with remote
Tries take the remote aparts,if can,some u can't they're tighten and latches from the inside.Take a rag soak it with some rubbing achahol and clean the PCB board and the inner rubbers plastics knobs on the sheet of rubber plastics that make coonntact to the PCB board.U tries take out the battery awhile and put in a brand new set of battery,remote might work for the volume button again.If not the volume control pad rubber knobe inner plastic pad that press down on the circuit board might be worn out or not making good contact anymore to the PCB circuit board.Or the remote control CPU chip are slowly shorting out the first command it take out was ur remote volume control functions.Try website like Remotes.com to buy another the tv original remote.
Aug 25, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
My sharp aquos lc-42d65u is not responding to my remote control . another word my t.v does not read my remote control at all. can someone help me to fix my remote ?
U already change the remote control for brand new batteries wright?Yes.Remote controls devices are heavily depend on it CPU chip for all of it functions.Test the tv manual buttons like Power,Menu,Volume - + and Channel + - all work?Yes.The tv remote control CPU is dead that why doesn't read the tv infered laser signal at all.Try website like Remotes.com to buy an original remote for the replacement.
Apr 04, 2011 | Sharp LC42D65U 42 in. LCD HDTV
Have Sky plus and the remote does not accept any codes I have got, so no volume control via Sky remote. Do you have the correct code for a Sharp Aquos 46" ? Thanks
please follow the steps below:
TV
RED + SELECT
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Brand new LC 42D65U
Sounds like your powerboard, take it back or call tech for replacement, dont settle for this, you paid good money for a working tv
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I get the volume to work on my sky remote control?
SHARP TV
TV
RED + SELECT
TV
0093 (sharp code)
press the power button if this turns your TV off then press SELECT to save. If not press TV then POWER. repeat this step until it does turn your tv off remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Sep 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
117 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
