Question about Coach Watches
How to use stopwatch - Coach Watches
Tag heuer stopwatch
Pull out the middle dialer once then try if that's doesn't work pull it again one will be the chronograph the other will be the stopwatch and if you turn the middle dialer it will change your clock
Apr 27, 2013 | Watches
How to stop stopwatch on revo rv1006 watch changed the battery but need to stop the stopwatch
Push the upper button once. The stopwatch hand will freeze. Push the bottom button. Stopwatch hand should move to ZERO position. Rate me, please.
Jun 24, 2010 | Watches
How could I remove alarm on junso 7064 stopwatch? or where I find manual for this stopwatch? thanks
Did you ever find a solution to turning the alarm off this stopwatch.I have the same problem.!!!
May 10, 2010 | Jwin Watches
Time set for robic stopwatch sc-707
where can I get the instruction manual for the Robic sc707 stopwatch?
Mar 25, 2009 | Casio AQ160W-1BV Wrist Watch
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
How do I set up and use the adanac 4000 stopwatch by marathon?
www.marathonwatch.com "Contact Us" They will email you the instructions.
Feb 09, 2009 | Timex T5G811 Marathon Stopwatch
Seiko Stopwatch with printer S149 - came with no manual for setup
Get it here:
http://www.everythingtrackandfield.com/catalog/matriarch/documents/SeikoS149StopwatchPrinter4220.pdf
Rate, please.
Feb 04, 2009 | Seiko S149 Stopwatch with Built In Printer
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Robic stopwatch instructions
Visit bodytronics.com/CTGY/Robic_Stopwatches - 65k - Cached - Similar pages
Choose Help Center, then Instruction manuals.
Find Robic manual download site, find your model and download manual.
Dec 18, 2008 | Watches
Watches Logo
23 people viewed this question
Top Coach Watches Experts
Jimmy Accardi
Are you a Coach Watch Expert? Answer questions, earn points and help others
