Question about Creative Labs Inspire P7800 Computer Speakers
Where can i buy a power supply for the sub woofer. Or what alternate power supply is safe to use?
I have no ac power supply
How do I install my sub woofer on model hw-hm45c
You can't easily
your model has no Sub woofer output
http://downloadcenter.samsung.com/content/UM/201411/20141114104111740/HW-HM45_HM45C-ZA-1114_Bookmark.pdf
you could get a crossover and buy a powered sub if you want to run it that way
Feb 13, 2016 | Audio Players & Recorders
Model No. PWR2006-37. Where can I buy a power supply?
Before rushing off to buy a replacement power supply, open your sub and check for a blown fuse.
Sep 01, 2015 | Philips Hts3450 5.1 Channel Home Theater...
Powered subwoofer has hum
First of all confirm if the hum is an internal or external problem.
Disconnect the RCA sub woofer input from the back of the unit and turn it on. If there is no hum it could be the interconnecting cable or the output from the receiver. But in the stand alone mode if the sub woofer hums when powered on you have internal problem and will have to be looked into by a professional.
Many a time the earth or the shield of the interconnecting cable is the culprit, because the sub sits on the floor and you might shift it for cleaning the floor and the cable can stretch and snap internally.
Apr 01, 2011 | JBL SCS145.5 System
I got logitech speakers X-230 M/N: S-0123A that need ac110-120v- 60 Hz from USA and by mistake plugged it into ac 220 v that is standard in new delhi. there was a spark and smoke from the woofer unit, and...
You have damaged the power supply unit and this would have caused some failures on the power supply and sometimes on the drivers.
So first of all please check the power supply unit, alternatively the DC power required can be supplied by incorporating a new power supply with the same rating but working on 220volt.
repairing the 110 volt supply is no good as you will need again a step down to work , so I suggest this change.
Feb 25, 2011 | Office Equipment & Supplies
Which circuit is used in sub woofer
the circuit for sub woofer consists of a transistor in parellel to the capacitor to supply power and moreover other I.C's or transistors depending upon the size of the sub-woofer achintya1915.jpg
Dec 06, 2010 | Office Equipment & Supplies
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Blown Amp AC?
Unfortunately, these older systems lose value rapidly and the cost of repairing problems like this can end up being as much as buying another system! Actually, you might be surprised to learn that JVC Service still sells many accessories and components from older systems. You can buy this sub woofer for less than $100, which should easily beat any repair cost you'll face. It may even come with the satellite speakers. The part number is VSDT2000R-SPBOX .
NOTE: JVC Service has a free shipping coupon going on right now, so you'd want to use that: DZYZXFX49GYZZ81
Also remember that there's a standard connection between the head unit and OEM sub woofer, so you're free to use a non-JVC unit. I would try to find one with a comparable power rating. Of course, the only drawback is that it won't blend in with the unit... but then, the sub woofer is usually tucked away out of sight.
Oct 12, 2008 | JVC FS-SD1000 CD Shelf System
Creative Labs Inspire P7800 Computer Speakers Logo
32 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
