A/c making noise and then switches off itself
I recently purchased a samsung split a/c as24eta series. whenever the compressor cycles on, it starts making sort of rattling and humming noise and automatically switches off on its own. can you please help?
  • esha_enjoy Jun 14, 2009
    we called a local technician and he says that the relay system of our a/c is faulty. any suggestions?
  • 378 Answers
Your piping system is cloging. call tech. to check it
Posted on Jun 14, 2009
The indoor unit of my 1.5 T , 2 yr old split ac is making noise like cracking of ice or plastic whenever the compressor is tripped or restarted. I've noticed water leakage (splash) from indoor un
indicates dirty evaporator fins that are icing up
that will overload the compressor and trip it
the ni oise you hear is the ice breaking up and the splashing is excessive water in the blocked drain that cannot run outside
get in a technician to clean and service the ac
Nov 24, 2017 | Heating & Cooling
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
I have just purchased and installed a Samsung AQ12FEN. A qualified Airconditioner company installed the unit. The slpit unit installation is a back to back configuration It replaced a 8 year old split...
This could be caused by an installation problem. The system could be severly overcharged, causing the compressor to load up and can cause a failure. i would start there. Is your intaller qualified to install these systems? (does he know what he is doing?)
I recommend, checking the refrigerant pressures first. You can also check the Polarity of the high voltage in to the outdoor unit. If the compressor is an Inverter Drive compressor, and the polarity is reversed, the compressor can run backwards causing the noise and eventual failure. To correct a polarity problem, simply remove the 2 high voltage wires that feed power to the outdoor unit from the board or contactor. Then reconnect those 2 wires, in the opposite position. (say you take loose from the unit and the Black wire is on the right side, and the white wire is on the left side. Simply swap sides, reconnect the Black wire on the left side, and the White wire on the right side.
Hope this helps,
Brian
Dec 15, 2010 | Samsung Heating & Cooling
Howl or whine noise inside after the a/c compressor lines replace
Be sure that oil was added when the new compressor and line were put in. It sounds as if the compressor is the one making noise. Is it a new compressor?
Mar 10, 2010 | 1999 Ford Expedition
SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Sep 02, 2009 | Samsung Heating & Cooling
1990 Dolphin Motorhome Dometic AC problem
If your fan motor is slowing or stopping mid cycle it will cause the compressor to over pressurize. Many compressors have aan internal mechanism that will kick in with a loud whooshing noise, then the Thermal protector shuts the compressor off, cools then restarts. If this sounds familiar, you will need to replace your fan motor before you burn up your compressor...which to be honest may already be irreparbly damaged(sorry). Hoping 4 the best.
Jul 11, 2009 | GE Quiet-Aire Ductless Split System Air...
Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Oct 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
