Question about RCA 32V550T 32" TV
Rca 32v434T need part numbers
Need Rca part number for horiz output transistor
  • 2 more comments
  • Anonymous Nov 05, 2007
    i need the part # for the horz output also!
  • Eugene Merritt Nov 11, 2007
    RCA Part Number for Q405 is 268428 (untested)
  • Eugene Merritt Dec 09, 2007
    I rated it already has leaky diodes on switching
    transformer switching transformer has been
    a problem for years in thompson Rca etc
    set is junk HOT may not be bad no odor
    only reason I checked on the part# is
    because it was so cheap $5.at mcmonline
    Its a refurb sold at Walmart that I found next to a dumpster
    just barely over a year old.RCA is poison around here
    I am not going to bother with it unitl after the holidays
    then I might take another look at it
    PS In case anyone out there is looking for the
    transistor that is not mcmonline, its here
  • 390 Answers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Posted on Feb 02, 2009
    Genius:
  • 1,694 Answers
RCA 32V434T Q405 = 268428 confirmed,however the
initial cause of Q405 failure is bad flyback transformer
Part # 271996 Replace both at same time..........T.
Posted on Dec 03, 2007
  • Vista Electronics Dec 08, 2007
    Any feedback would be appreciated...................T.
  • Vista Electronics Dec 09, 2007
    I have changed dozens of Thomson IHVT's that had no odor....
    Sometimes just the transformer is bad and transistor is still
    OK....Usually set clicks three times..............
    Leaky diodes related more in the past with failures in CTC169
    chassis....big screen and direct view..........T.
    I welcome your completed repair feedback...........
I need to know the datasheet for the horizontal's transistor for a tv RCA 32F531T, because I lost the replacement
Hello
The number of horizontal output transistor is [TL 035]. If this number is not available, you can use exact substitute after reffering it to transistor data book and equivalents. OK.
Jun 03, 2011 | RCA 32F531T 32" TV
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
Transistor d1878 get over heat
i have a sony kv-2197m3 i replaced tr D1878 tv turn on,but image it's bad in horizontal seize and tr D1878 was shorted again what's the matter? chek68@gmx.fr Post Solution
Oct 11, 2009 | RCA 27F530T 27" TV
RCA32V434T
The Horizontal Output transistor needs to be changed as it is most likely shorted. The current transistor on this set is a 2SD3402 (no longer available) it's new replacement part number is the 2SC5902.
Order 2 2SC5902 Horiz Output transistors.Replace the transistor by it self once and if all is ok then fine.
If not replace it again and also the the Flyback HV transformer. The HOT transistor is probably shorted again and the transformer is causing it.
Dec 27, 2008 | RCA 32V550T 32" TV
My tv has no picture or sound. it makes a sound like its about toi come on but it doesn't. a red light just flashes
Dec 21, 2008 | RCA 32V550T 32" TV
Tv problems
Sounds like the high voltage stages aren't firing up. Could be a number of things: Blown fuse, bad horiz output transistor, bad regulator IC, bad flyback transformer.
The reason this happens is because the high voltage also supplies the rest of the voltages needed to operate.
Geno
Mar 18, 2008 | Televison & Video
RCA Guide Plus Gold Gemstar
The set tries 3 times to come on (3 blinks) if there a problem such as a short, it will cycle without turning on. Unfortunately your set is notorious for having bad flyback transformers. Most likely the horizontal output transistor is shorted as well. Common causes for your symptom are: LL05 (horiz out transformer) RCA part# 257805; TL 02 ( horiz output transistor) 2SC5148; and open connections on the printed circuit board at LL 04 and L14401 (coils) all of which can cause the horizontal output transistor to be shorted.
0
Nov 25, 2007 | RCA F32450 32" TV
Need part #
Can you read the letters and numbers on the transistor your needing to replace? If so post the numbers and I will post a link where you can order them or their substitue.
Nov 14, 2007 | Samsung HCL4715W 47" Rear Projection...
No picture High pitch squeal RCA F36650
Confirm service # from back of set = F36650 YX01..........
Transformer red HV lead attaches to CRT & Horiz output
xistor is on heatsink next to transformer = 2SC5148 .........
Rca part # 257805 or ASTI 2078 and 237470 xistor............
Do not use a generic transistor = name brand only............T.
Please rate this solution..............
Nov 12, 2007 | RCA F36650 36" TV
Part number
oh an easy one LOL That part # is 1-453-268-21 and available at http://www.partstore.com at a price of $82.12. One thing though Make sure you check the horizontal output transistor with all the leads disconnected from the curcuit as this part sometimes goes bad when the fly does. My regular practice with any flyback replacement is to automaticly replace the HOT(horiz. output transistor) as well as resoldering the hhorizontal driver transformer and the horiz. driver transistor. Hope this assist yout repair and makes a happy one. Thats what were here for! Good Luck.
Apr 18, 2006 | Sony KV-27S42 27" TV
RCA 32V550T 32" TV Logo
529 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
