Question about Kodak Office Hero 6.1
Will not recognize new print head - Kodak Office Hero 6.1
Why is printer saying printer head not there when i put all new ink cartridges in it?
PDF]Cleaning the printheads - Lexmark
www.lexmark.com/publications/pdfs/lexmarkj110/.../clean.pdf
LexmarkThe carrier moves to the load position at the center of the printer. 6 Raise the ... If this does not solve the problem, a printhead may be plugged with dried ink.
Lexmark ink cartridges with print-head, not recognized ...
? 6:48
https://www.youtube.com/watch?v=v2wMm4uMWpg
Sep 16, 2013 - Uploaded by PrintingExperience123
Lexmark ink cartridges with print-head, not recognized, missing, damage, chip problem, .... The error reappears when you try to use the printe
Nov 30, 2015 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
New ink cartridge is not printing. The diagram shows that the machine recognizes that it is there, but no red ink is releasing.
Inkjet printers do not like being left unused.
The color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 16, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
When I turn on my printer I get the message "The following ink tank can not be recognized" Then nothing works. The tank is the magenta and I replaced it - still nothing. Anything I can try to get the...
if its still doin same thing with new genuine inks probably ur print head or carriage unit is faulty.. my recommendation is take ur inkand try with ur friend's machine if its working then we'll know that the head or carriage unit is faulty.. and its %80 print head.
Mar 29, 2010 | Canon MP830 All-In-One Printer
Won't work after installing new ink cartridges
This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | HP DeskJet F380 All-In-One Printer
Canon MP520 error U051 insert print head, no print head. This is a new printer that was not used for 4 Months. What do I do?
The printer not recognize the print head at the moment.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Clean the contacts using cotton and some alcohol.Then put all back and try again.If this not help you need to replace the print head.It's part number is QY6-0070
Oct 30, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Print head
Check that all, printhead and ink are seated and contacts are correct.
Power down the printer and allow for a complete power on and self test.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Kodak Office Hero 6.1 Logo
29 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
