Question about True 72 cu. ft. / 2039 liter Commercial Freezer T-72F
Freezer door is very hot to the touch on the outside
The freezer seems to put out a lot of heat and when I touch the outside of the door it feels very hot. The outside temp gauge is broken but the inside is working correctly. why is the door so hot? is this normal?
  • 1,772 Answers
Hello, their are heat coils in the doors, their maybe a issue with the door heat circuit controls.
Posted on Nov 11, 2015
My 82L Upright Freezer from The Good Guys - a GVA is very hot on the outside - almost too hot to touch. Is this normal?
yes
the freezer works by taking the heat from the inside and exchanging to a coil that is under the outside of the freezer
It will be quite hot until such time as the inside temperature is brought down to the setting
the thing with freezers is that on start up the food that you are putting in should be cold to start with and not hot ( if necessary , use a bag of ice as a helper ) Later on any hot food added will not affect the operation that much as it is be in small quantities
this would be explained in the user booklet that was inside the freezer
Jan 09, 2016 | Freezers
Why is ice forming around the inside freezer door?
You have bad door seals. Try hitting with a heat gun type, dryer just a little heat.. Then close door for 24 hours
Oct 29, 2015 | Freezers
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
The outside front of the freezer case gets hot.
It's normal to touch it hot on the outside front.
Because it has heater to keep moisture out in the body metal of the freezer.
Those moisture if not heated to dry, can cause rust build up.
Rust build up can destroy the metal body of the freezer.
Thanks for asking.
Jun 29, 2011 | Woods Chest Freezer C1501W3
We have a general electric 20 cu ft chest freezer. the outside becomes hot to the touch is this normal?
Yes, the freezer / refrigerator is a heat pump, it transfers heat from the inside to the outside. Heat transfer effitiance is reduced if the outside is at hight temperature, so it is sudgested to allow free air flow for the back of the cooling device (where the radiator is )
Aug 05, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
157 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
