Question about Fujitsu LIFEBOOK U772
My fujitsu lifebook U772 continues to freeze after only a short time of use
The computer freezes when trying to load backup after the screen becomes locked, in particular. I have tried to remove thescreen lock or sleep mode, but problem persists of freezing after a relatively short period of use. No heavy software is being used. Usually just Internet Explorer. We have tried switching to Firefox, but the problem continues to exist.
2 Suggested Answers
technical114
  • 1851 Answers
SOURCE: Please i use a fujitsu laptop E lifebook. When i
I have to tell you that 1 long beep followed by 2 short beeps are generated from bios for vga errors... This means that you have to get your laptor at the technician as sooner as posible in order to check the vga part of the motherboard for ventilation problems (that's the best solution for you) or for motherboard replacement (I don't think that this solution is very comfortable, since it will cost as a new laptop)
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 26, 2010
My laptop is fujitsu lifebook U772 but I recently could not use it . I see nothing pop up after I pressed the on button and the screen remains in black even though there is blue light indicating the...
Shine a light against the screen when you power it on. If you can read anything on the screen then it is a back light or inverter failure. Hook up an external monitor to it if you can and see if that helps show anything.
Jun 30, 2014 | Computers & Internet
Fujitsu lifebook s6520 is not comes ON when i press the power button the lifebook comes ON its all LEDs & processor fan sound is listened but then just NUMLOCK led starts blinking after that blinking...
Is the monitor working. If have not checked it try connect it to an external screen. If the screen is okay, try and remove memory (RAM) and after ten seconds you place it backup and start the computer and check.
Dec 06, 2012 | Fujitsu LifeBook S6520 Notebook
How to install webcam for fujitsu lifebook a530 ?
Hi'' on a brand new web cameras mostly all brands has an installer driver . as you have it ' unlock deep freeze if it does not have a system lock then go and insert the installer to its DVD Rom then run it to install, then click finish. thanks for using Fixya. . .
Sep 14, 2012 | Fujitsu Lifebook A530 15.6 inch Notebook...
Laptop freezes right after icons appear will not go to internet
1. Try to upgrade your Internet Explorer to the latest version first.
2. Install a Good Antivirus & Scan to delete all infections.
3. Uninstall all toolbars of internet explorer.
4. Disable some unused Addons from Internet Explorer (Tools>Manage Addons).
Update your Adobe Flash Player.
Aug 06, 2012 | Fujitsu LifeBook N6410 Notebook
Fujitsu Lifebook c1410 froze
plesae check your hardisk, and also check your ram,
Nov 30, 2011 | Fujitsu Lifebook C1410 Notebook
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Please i use a fujitsu laptop E lifebook. When i boot the system on but gets a black screen. i tried taking out the hdd and still the problem persisted. Some times when i continually boot for couple of...
Thanks and regards
Stelios
Jun 26, 2010 | Fujitsu LifeBook E7010 Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
My Fujitsu LIFEBOOK N3430 Notebook does not boot up the screen is blank
Remove the battery for 5 minutes, press and hold the power button for 3 seconds, wait 5 more minutes, put battery back in and see if everything works now. It should. This usually works.
If it doesn't, you may have a faulty memory chip causing you the black screen.
You can try removing one at a time to see if it corrects the problem.
Lastly, the ribbon cable from screen to motherboard can become piched and non responsive.
Nov 25, 2009 | Fujitsu LifeBook N3410 Notebook
Fujitsu LIFEBOOK U772 Logo
46 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
