Question about Garmin nuvi 350 GPS Receiver
Opening the Garmin Nuvi 350
How do i open the unit to check the circuit board?
Re: Opening the Garmin Nuvi 350
It can be easyto open. There is a couple of nuts behind the antenna, you have to remove them, then you need to remove the antenna, in order to do this you need to find a pin in the base of the antenna, and slide it to the center, and this free your antenna, then you can reach a couple a nuts located under the antenna, remove them and then you will be free to open your nuvi. I did this cause my power button was broken, I resolded and now is working pretty fine. the picture is my nuvi 350 opened.b67f991.jpg
Posted on May 07, 2008
I did as the mentioned in Solution #2 posted Feb 2008. and it worked!! There are two connectorsthat are kind of flimsy, it took me 45 minuted to take it apart and figure out how to attach the cables. crappy design for sure but now it GPS is working again. Yippie. Thanks for the help... Solution #2 posted on Feb 26, 2008
Posted on Oct 29, 2008
I've been looking for this info all day.. fair play to ya!
Posted on Jun 26, 2008
  • 504 Answers
This unit is not designed to be serviced by the user. If you have experience in servicing this type of device, it may be possible. If you do not, I would recommend returning the unit to Garmin for service. Attempting to open the case may damage the unit.
Posted on Feb 26, 2008
0 characters
3 Points
Touch screen doesn't respond. Garmin had me do everything including usb port to upgrade. After 45 minutes on the phone doing everything they said to do, they told me the unit was no longer able to...
The touchscreen is critical in using the Nuvi 660 - without there's no way to diagnose the problem from the outside. USB communication can still work, making software updates possible as far as it goes.
If it's not under warranty - opening the Nuvi 660 is a path to consider. Preferably by someone who's experienced with opening Garmin devices or (smart) phones. The Nuvi backcover is fitted with Hex / Torque screws - and is relatively easy to open with the right tools.
First area to look for is the flat cable connector of the touchscreen - reinserting the flatcable in the Printed Circuit Board connector. Be sure to disconnect the battery first. After reinserting the cable - connect the battery and try again if the touchscreen now works.
If the problem remains - clean the unit with pressured air - possibly removing contamination/dust causing (capacitive) shorts.
Jul 07, 2011 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
How do you open a nuvi 350 Coffee leaked into unit under display screen. Unit still works fine.
If you don't get any advice on opening the unit then you can evaporate any liquid back out. Suggest you put it in a warm location for a few days and let the water content evaporate.The dry residue shouldn't cause any problems and it will probably be stuck to the surface that the liquid was touching at the time.
Jan 15, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 350 9 months old
Have you ever tried updating the firmware with garmins webupdater?
Have you had this issue with a fully charged battery.
Do you hear anything rattle in the device when you shake it....I had a spIII color with similar issues, found out that one of the circuit board mounting screws was travelling around in the case.
If this is the case, and you are tech savvy you could open the GPS and probably find the culprit. If not ship it back to Garmin, for it is still under warranty.
Jun 11, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuva 350 GPS
The USB port is soldered to the circuit board, it didn't slide in, it broke due to brute force. I think you have to fork out $170
Apr 14, 2008 | Garmin nuvi 350 GPS Receiver
Power button failure
There is a well known issue with power switch failures on this unit. It happened to me as well. I have heard that you can power the unit on with the car charger or if you plug it into the PC using the USB interface. I will try this tonight and report back my finding. I will be taking mine apart because of my bad experience using Garmin's technical support line. Most likely the problem is a defective switch or broken solder joint where the switch connects to the motherboard. Remember also, you have to hold the switch down for a couple seconds for the unit to power up.
Jan 13, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350
you need to solder the headphone jack connection on circuit board,how do I open the case without cracking it,there is some resistance on the side the switch is on
Oct 11, 2007 | Garmin nuvi 350 GPS Receiver
Garmin 350 Nuvi
not sure if you are keeping the tab open but...the reason is because the tab at the top of the GPS is the antannae. You have to open it or it won't work. when you press the reset button, you are opening the antannae first which then acquires the satellites. Keep the top tab open.
Sep 21, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
9,065 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
