Question about Air Tools & Compressors
Feed system cs6000i - Air Tools & Compressors
Feed Dog Instructions on how to use or trouble shoot
Not sure if this model has a Feed Dog switch. May be located in area covered by storage portion of sewing bed. May be located on back side of freearm area will be indicated by multiple triangles near the switch.
Cheers,
Kelly
San Diego, CA
Embroidery Services
May 11, 2014 | Brother CS6000i Computerized Sewing...
The feed dog in the brother cs6000i wont stay up
sounds like the feeddogs or the feeddog lever needs to be replaced
if you want parts try
sewingpartsonline.com
premiersewing.com
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
Brother CS6000i feed dogs issue :(.
sounds like something may have broke or come loose,, I'd take the machine to someone else to have it checked to see what the poping sound was
Mar 09, 2012 | Brother CS6000i Computerized Sewing...
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Feed dogs won't raise when I switch the switch in back. How can I take off the back to see what's wrong?
Befoe you try to take it apart, the machine needs to make one or two revolutions before the feed will come up. try that and see if it works.
Jun 01, 2010 | Brother CS6000i Computerized Sewing...
I have a Brother CS6000i & the feeddogs are stuck in the down position, even though the control for it moves like it should.
Be sure and let the machine make a couple of sitches to see if the feed will come up. Flipping the switch does not raise the feed.
Feb 22, 2010 | Sewing Machines
The feed dog is not pulling the fabric and I cannot get it to come up
Hi, possible causes: see if there is an up and down movement of the feed dog during a cycle. If it moves check that the throat plate is not the feed cover plate used where fabric feed is not needed. If there is no movement, check that the setting is not for embroidering where the feed dog is neutralized for free motion stitching. Otherwise open the buttom cover and observe its movement under various sewing settings.
Aug 05, 2009 | Brother CS6000i Computerized Sewing...
Air Tools & Compressors Logo
24 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
