Question about Jandy Pool & Spa
My jaccuzzi empties when
Jacuzzi empties
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need more info but if a pool and spa combo check the actuators to see if on or in the right position for pool then in spa if need more ifo please contact me
Posted on Sep 25, 2014
I have an older Jaccuzzi hot tub w a balboa h136 board and single button topside control. The hot tub will not heat. The LED lights up on low speed and goes off on high speed. I just replaced the heater a...
You have voltage across the element but no heat....
Disconnect one element connection and do a resistance/continuity test. Or use a clamp to measure running current.
Feb 13, 2015 | Jacuzzi Home
Looking for the 3 in flapper gasket for a jaccuzzi brand toilet. The local jaccuzzi store told me LOWES has it, but they dont and my toilet is currently out of service for it. Is there somewhere i can...
The Jacuzzi website sends you to dealer websites; Lowe's is the only one that stocks toilet flappers. Of the 34 different flappers they stock none are specifically mentioned as a replacement for a Jacuzzi product. You are probably best served by choosing the Universal model that approximates the style in your toilet and connects and operates in the same manner.
Check the on-line listing of toilet flappers from Lowe's here. You can locate a nearby store with stock or order on-line and choose to have the product delivered.
Jan 30, 2011 | Home
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Can't find replacement seat for the toilet? Where
You can't be serious? Get yourself down to Loews, Home Depot or Menards and get yourself a seat brother! It's not rocket science or that only Jacuzzi seats fit fit Jacuzzi toilets lets get real, comon lets get er done PAL.
Jul 26, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Our sink is a double sink,black enamel --- one night it simply started poping the enamel off. Piece by piece the right inter left side poped off. We were gone all day, there had not been any water in the...
Just a note here that this phenom does happen just like toilet tanks just crackin while you are sitting in the living room watching TV. There is no explanation for it.
While I personally would not expect any manufacturer of anything to pony up 2 years after their warrenty expired, to each his own. I do however believe it would be good public relations if they gave you a replacement.
I understand your anger and frustration but I ask to to remember that getting a Ford Mustang that is a total lemon from the factory does not equate to all Ford Mustangs being lemons or that everything Ford makes is a lemon.
Godd luck and I hope they come through for you.
Mar 29, 2010 | Jacuzzi Kitchen Iron Black Finish...
Our Jaccuzzi Magnum Force pump extremely low pressure
Giving it a good cleaning probably clogged the pump impeller. If you vac'd the pool and the pump basket was packed with debrie it probably passed through and clogged. Split the pump and inspect the eye of the impeller. Low pressure means low flow.
Aug 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jets are draining my jaccuzzi tub
Check to see if there is an open valve where the water exits the tub. If there is a valve, shut it and your problem should be solved. good luck
Jan 15, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Will not start
All jaccuzzis must have a GFI breaker or outlet where it plugs in. Find either and reset
Oct 04, 2008 | Jacuzzi Amiga Whirlpool JAC-N888...
Pool & Spa Logo
32 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
