Question about Jandy Aqualink Rs4 One Touch Control System Control System
My jaccuzzi empties when the pool pump is off
    Top Expert:
  • Jandy Master
  • 5,096 Answers
Check jandy actuators make sure they are on in correct positions and make sure they are locked in so they move also check for cut wires
Posted on Jun 07, 2015
Do I have to empty my pool to replace the side supports on an intex above ground pool
they keep the wall up. so, I would suggest to empty the pool.
Mar 08, 2015 | Intex Pool & Spa
How to wire a 2 speed pool pump for a jaccuzzi bathtub?
should have a schematic on the motor
Aug 30, 2014 | Pool & Spa
How do i wire a 2 speed magnetek/century pool pump
see schematic on the side of the motor
need more info but if a pool and spa combo check the actuators to see if on or in the right position for pool then in spa if need more ifo please contact me
Mar 18, 2014 | Jandy Pool & Spa
The polyethylene tubing fell/broke off the air button under my jacuzz. It's a clear tube with a black connector inside. Can I glue it, do I need to to buy a new connector, or do I need a new air button?...
i would tr to glue it, clean all parts with alcohol and sand with sand paper, making sure parts are dry apply epoxy, and let fully cure, carefully reassemble..vote if'n I was of help.. jay the pool pump motor repair guy in longwood florida
Aug 04, 2013 | Jacuzzi Pool & Spa
I have a Jacuzzi Z110 hot tub. the top control is broke (pn 51422). Can i use a digital top control PN 33334.
When dealing with a big manufacturer like Jaccuzzi, it is unwise to swap top side controls. They make theirs proprietary on purpose so that swapping is more difficult (especially jacuzzi).
If you use the wrong one, the buttons on the controls will be misleading (such as temp up button cycling jets, or the ozone button cycling the lights, etc)
I would use manufacturer part.
Oct 01, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
All water empties from the pump back into the
This is a leak in your system. If it is just slowley going back to the pool it is probally on the pressure side (after the pump). If it goes back with a big wosh it is probally a suction side leak (before the pump).
Feb 01, 2010 | Water Pik Aqualink Rs4 Package - Pool and...
Our Jaccuzzi Magnum Force pump extremely low pressure
Giving it a good cleaning probably clogged the pump impeller. If you vac'd the pool and the pump basket was packed with debrie it probably passed through and clogged. Split the pump and inspect the eye of the impeller. Low pressure means low flow.
Aug 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Using a hayward vari-flo valve model SP 710x32
Do not drain a vinyl liner pool mor than half way....ever... If you have a fiberglass, or gunite pool it is important to pull the hydrostatic plug under the main drain cover. If you live down a hill, or where there is a high water table, the water pressure underground can lift the empty pool out of the ground (more common in fiberglass pools). If you have a sand or DE filter switch the valve to waste. make sure that you have the skimmer turned off, and the pump is only sucking from the pool main drain (spa drain closed also), and turn the pump on. Make sure the waste hose is far enough away so you dont add any hydrostatic pressure.
Mar 27, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
