Question about Technics Audio Players & Recorders
Once the needle touches 33 lp it speeds buy the songs
    Sergeant:
  • 432 Answers
Yes the platter speeds up until the moment comes. 0'5 sec later and then the electronics take over , want you to try quartz activated and after that quartz put out and then you have a pll. try moving the pitch a bit, cause the 1210mk2 aint tables which you want for the good maintainence. if it helps or doesn't , mail as fast as you can
Posted on Sep 21, 2014
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
Playback on the turntable is sped up
The first step to resolving this issue is to select the appropriate RPM speed for the record that you have in hand. If it is not a simple 33 1/3 RPM record set on 45 RPM, then it would seem that the phono motor speed could require adjustment. Your phonograph is a belt-driven PX-E860 K with a DC servo motor.
Some people mistake the the 7"/LP record size LEVER for the rotational speed BUTTON (33 RPM when raised; 45 RPM when down).
In the case of needing to actually callibrate the rotational speed, underneath the unit there is a hole labeled "33" & a hole labeled "45." Using a very fine precision screwdriver, you can callibrate the speed of each. Insert the screwdriver into the repsective hole past the rubber & slightly turn the screw (rotational speed increases as you turn the screw clockwise).
Jan 07, 2011 | Aiwa Z-L500 Shelf System
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
WHEN I PLAY A 331/2 RPM LP IT SOUNDS A LITTLE
The needle itself will not induce drag on the record. Even worn needles play no role in the problem you describe. The belt, provided it has suffcient tension to turn the platter, is doing it's job. The most likely source of malfunction is the motor itself. Try sliding the speed switch back and forth while the turntable is turning. If you see no difference in the speed between the 33 1/3 rpm setting and the 45 rpm setting, you have most likely eliminated all sources of the malfunction other than the motor. They are very prone to failure. If a replacement can be found, the job of installing it is not particularly difficult but indeed should be left to someone skilled at soldering electronic parts.
Dec 22, 2009 | Seth Thomas Pacconi Turntable
My Sony PS-LX250H is all of the sudden playing too slow with a 33
Not sure what made it happen all of a sudden, but you might want to check out Mocamom1 's question related to PS-LX250H speed & the attached solutions. You may just need to adjust the SW screw on the underside of the unit (worked for mine that was playing everything at 35 1/4!)
Jun 27, 2009 | Sony PS-LX250H Turntable
My USB Turntable changes speed, at the end of a 33 RPM record
Get yourself a new turntable. ION units are very poorly made, and the company does NOT provide any sort of after market support. Once this breaks, you cannot fix. The company does not provide any parts or support for their products.
It's meant to break, and yours just broke. More than likely the IC (Integrated Circuit) that controls the 33/45 function has been damaged - you cannot get this part.
Sorry, couldn't be of much more help.
- OPTiC
Master Tech
Digital Analog Therapy
Turntable Repair : Turntable Parts
Jun 13, 2009 | ION Audio Vinyl Recording Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Crosley CR-49 Turn table stops and will not play when needle arm is positioned to play a song toward the end of the 33 album.
The tone arm may have been forced out of spec to play an entire LP, or the auto cutout function of the player appears to be operating.
If out of adjustment(someone has forced it), the problem can be resolved by loosening the screw that locks the tonearm to its turret, and adjusting the end travel against the distance to the end of the LP you mentioned it wont play. Then of course tighten the locking screw again
Another common problem, is where dried grease between the two small metal plates fixed to mechanism that engage against the center spindle to activate the autostop mechanism. You will need to remove the platter in most cases to get access to this autostop mech to clean away the dried grease and or adjust it.
Good Luck with your listening. Long Live Vinyl :)
regards
Graeme
Feb 28, 2008 | Audio Players & Recorders
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
