Uable to complete format in windows 7 - Computers & Internet
Files wont completly load when i start computer
Dear There ....
Your system file will delete by the virus infection so now you have a two option 1)Complete Format 2) Repaire
if you choose the format option then your c: data will lose, and if you choose the repair then existing windows will repair and your data are safe.
But first let me know which Windows Version you are using .....
Windows 7:
Windows 7 New Installation
Windows 7 Repair
Windows XP:
Windows XP Installation
Windows XP Repair
Thanks to Visit Fixya.....
Prashant
Sep 05, 2012 | Toshiba Computers & Internet
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
Dec 14, 2011 | Samsung R580JBB2 Notebook
Formatting USB1TB with the Fat32 tool, the tool says it's completed formatting, but hte drive is not formatted under Windows 7 (which also can't format the drive).
FAT32 only supports up to 4 Gigabyte drives. It's not possible to format a 1TB drive with it. You should format the drive using NTFS which Windows 7 would also recognize. What operating system are you using to format the drive?
Aug 23, 2011 | Computers & Internet
I have a lenovo g540..why not supported window 7 ? if i installing window 7 always blue screen when completing installation
All computers with minimum requirements are able to install Windows 7.
The installation CD you are using must be faulty,
use a new Windows 7 CD, and it should work.
You can also try to format your Hard Disk during the installation process to remove the old damaged Operating system files, if you are not performing a disk format, please make sure you back up all your data to a separate partition or an external drive before formatting as all your data will be deleted.
Thank you for using Fixya,
Kenneth
Jul 26, 2011 | Lenovo Computers & Internet
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Jul 11, 2011 | Computers & Internet
Sd card format software
Start up a computer with Windows XP, Vista, or Windows 7. Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Computers & Internet
I have win 7 and win xp loaded on my lap..How can I delet xp now?
You need to check if there any Boot Information in partition that is used by WinXP. In this situation best way is to reinstall Win7, and format all your partitions as you want in Win7 installations process.
Apr 18, 2010 | Microsoft Windows Vista Ultimate Edition
Want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
Nov 01, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
New memory card unable to format
if there is a little slide on the side of the card try moving it to its other position either up or down
Mar 25, 2009 | HP Photosmart M525 Digital Camera
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
