Question about Philips 27PT5445 27" TV
I have a line at the top of the screen which looks as if the picture is reflecting down. It starts furthure down but as the tv is on for a while it moves up
  • Philips Master
  • 1,229 Answers
You have a bad capacitor near the flyback transformer. I beleive it is a 100volt 10 Mf at 85degrees. Replace with a 100volt 10Mf at 105 degrees. This will cure your problem. Ah yes the location# is 2465 and near the flyback transformer. Be extra cautious, because the pc trace is delicate and you can ruin this and the TV. And you may as well replace capacitor 2415, it is a 160 volt 2.2 cap. By now it is week and will cause a shut down soon. Relace with same value at 105 dgrees for more dependable time! This cap is north east of the flyback transformer! Good Luck and be careful!
Posted on Apr 07, 2010
  • matt martin
    matt martin Apr 07, 2010
    Replace capacitor 2465 a 100 volt 10Mf at 85 degrees. You same value only at 105 degrees. Be care not to pull up the trace this cap is attached too. You need extra caution here!
Black line on top of screen dips down and has
Please post your make and model number printed on back of TV.
Mar 07, 2010 | Televison & Video
Mitsubishi VS-1561
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Jan 05, 2009 | Mitsubishi WS48511 48" Rear Projection...
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
Jul 23, 2008 | Philips 27MT3305 27" TV
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Jul 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
32Inch Flat Screen SDTV - with picture distortion
If you have a TV shop at all any more in your area, any tech working on them will know where to look. This is a pretty common problem although you are getting it too early.
Since it will require a certain type of instrument (capacitance meter) to verify the problem part, I don't want to go into detail concerning a 'do-it-yourself' repair since it may be a little difficult to order these in single quantities and a decent shop should have the right value on hand.
It shouldn't cost too much.
Jun 28, 2008 | Philips 30PW633R 32" TV
Colored Lines Destorted Picture
I had the same problem , sent it into the shop and they said it was a capacitor . It is a $3.00 part and $75.00 for labor . But it did fix the problem . The labor charge was inflated I'm sure so if you someone who can do it and just get the part ,would be the way to go.
Apr 13, 2008 | Philips 32PT5441/37 32" TV
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Philips 27PT5445 27" TV Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
