Question about Coffee Makers & Espresso Machines
Rust spot on granite countertop
How do i get rid of rust
  • 95 Answers
CLR or rust remover for clothes and hard surfaces.. Muriatic acid at Lowes is cheaper at 2 gallons for $ 8.00 , for really cleaning pools but very toxic
Posted on Mar 19, 2014
My black granite countertop has a stain which must have soaked thru seal, now shows a whitish spot, How can I fix this? Thanks
Remove Water Marks/Stains from Granite Countertops ...
? 2:55
https://www.youtube.com/watch?v=VO571n_4Jns
Jun 10, 2011 - Uploaded by KristyU2178
... the water mark/stain from my black granite countertop in mybathroom. ... @TheJefferyjones The stains ...
Removing Stains from Granite Countertops - YouTube
? 5:51
https://www.youtube.com/watch?v=hPPFe8902Zg
Oct 1, 2010 - Uploaded by MonkeySee
I left a bag of sweet potatoes on my black granite and there were some ... @Oxidized181 yes I have lots of ...
Stains on Black Galaxy Granite - Countertops
Jan 17, 2016 | Home
Help, ive tried 3 different poultices on my granite countertops and the stains are still there!
Test on a very small spot where the stain is with auto transmission fluid.worked for me.
May 08, 2014 | Building Materials
Can i use linseed oil on my granite counters
you should not use linseed oil or any other oil on granite countertops unless the desired look is a darker stone. The oil may not penetrate depending on the color and density. Linseed oils are generally only for soapstone.
Apr 28, 2014 | Building Materials
How to make my granite shine with inexpensive products
There is not really any product you can put on your granite to make it shine more. It should have a natural shine from the quarry. Some granites are "commercial grade" and have been poorly polished, only a professional would be able to polish it if this is the case.
If it has gotten duller over time, it is likely a residue that is causing the problem. (soap scum, water mineral deposits, etc) Try #0000 steel wool to take the residue off (rub hard) (test an inconspicuous area first) do a small spot first to see the results.
What is the solution to fixing small chips in my new granite countertop? The granite countertop was just installed a month ago and the company has not not responded to my letter about the chips in the...
Try using super glue, the thinner the better the adhesion. Once it is dry hold a single edge razor blade (use extreme caution, razors by nature are very sharp) perpendicular to the surface of the stone and scrape the glue flush, changing blades regularly. Do not use the blade to cut, as it will dig in and pull glue and possibly stone out, as you have discovered. Just take your time and scrape the glue until it is flush with the granite. If the spots are dull, you can use a little carnuba wax (automotive/hardware store) to shine it up. Some types of granite have more texture due to differences in the makeup of the stone which also gives the variety of color. I have filled entire countertops with this method, and it is tedious, but yields good results.
Feel free to contact me with any questions. Brandon Wiese
Dec 26, 2010 | Stone TOP ONLY: 21 in Black Granite Vanity...
New granite countertops big circle spots on.
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
Dec 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Aug 07, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Small chip in granite countertop
Well you should seal your granite counter at least once every two years because granite is pourus. Theres something called Granite Guard you can use to seal your counters and other different sealers as well. You can pick some up at your local home and garden supply store.
Apr 02, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Dec 19, 2008 | Dishwashers
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
