Question about Genesis 29 Inch Two Nine Mountain Bike
Replace rear tire - Genesis 29 Inch Two Nine Mountain Bike
Replace rear tire
Hi James
Yes you can replace the rear tire, just follow the steps in the bike owners manual or buy a service manual. After the tire is off if you are not comfortable removing and replacing the tire from the rim you can take it to a bike shop and they will change it for you. I hope this helps. Rod
Jul 25, 2015 | Motorcycles
Alignament rear suspension
I replaced the rear struts, when removing i discovered one was totally bad, they didn't seem bad from testing and recovered quickly when pushing on the bumper, but were bad. after replacing my rear tire wear is even after 5k miles. mine were wearing from inside to outside too.
Apr 21, 2013 | 1999 Honda Civic
I have 2002 honda civic with noise coming from rear sounds like a noisey wheel bearing have jacked up both sides and spun wheels with no sign of noise .
Check Tires for feather edge. Join your fingers together, move around the rear Tire from front to back and vice versa on both of the rear Tires and feel the smoothness. If the tread of the Tire resist the fingers in one direction and smooth on the other, then the Tires may be producing the abnormal noise.
Temporarily bring both the front Tires to the rear and rear Tires to the front on the same side, drive the car and watch the noise. If the noise begins to come from the front end, then the Tires are defective and need replacement. . If the noise still comes from the rear wheels then the rear wheel bearings need replacement.(You can also rotate the Tires in criss cross manner temporarily)
The bearings often vary noise with and without load. Be sure to troubleshoot the noise before spending money on costlier spares.
Feb 23, 2013 | 2002 Honda Civic
Slip Control Coming on Infinity G35 6 Speed Coupe with New Tires
you have a computer for your control on your car. It is set up so only the factory front and rear tires sizes will work, any change, it picks it up. this should solve the problem.
Aug 28, 2009 | 2002 Cadillac Deville
What tires to replace first
Have the technician replacing the tires put the best 2 used tires on the rear of the cars and put the new ones on the front. You do your steering and braking with the front tires and if you were to have a blow-out, you want it to happen on the rear tires so that you can maintain maximum control with the good front tires.
Jul 24, 2009 | 1998 Ford Crown Victoria
Rear end has problems tires are bowes out bad
sounds like your problem is a bad bearing
May 01, 2009 | 2000 Ford Focus
Tire heat
the Vulcan has never been hit and no unusual wear appears on the rear tire. The pressure is at the recommended level (28psi). Thanks. You're good to go nothing to worry about. MC tires utilize very soft compounds and rely on warm-up to perform their best. I just replaced my rear tire after 9200 miles and the front looks like it will go another 5,000. That's the same experience I had on my NightHawk as well.,,,
Nov 10, 2008 | 2003 Benelli Tornado Tre 900 LE
Rear wheel
does the van shake or vibrate? does the van have tires on it ?start by switching the left rear with the right rear test drive and listen for soun if no sound then the tire has a bad steel belt replace tire if the sound is still present. jack up van and spin tire if no sound is heard replace wheel bearing and if there is still a sound look into brake drum for possible springs or clips that may have fallen into drum causing noise but i would say its more than likely the rear wheel bearing to change that u must buy a new bearing and follow instructions on replacing good
Jun 30, 2008 | 2000 Dodge Caravan
Genesis 29 Inch Two Nine Mountain Bike Logo
Top Genesis Cycling Experts
rdjagger
ray gallant
dante
Are you a Genesis Cycling Expert? Answer questions, earn points and help others
