Question about Boating
Mercury 15 leaking fuel wont start
Mercury marine boat motor 15 hp
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Where is fuel leaking from ? give me past history how it came to not starting ! carb clean ? sparking at the plugs ? compressions ok ?
Posted on May 12, 2014
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 53 Answers
SOURCE: Yamaha 115hp 2 stroke Outboard Boat Motor. Went
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
Posted on Nov 01, 2009
  • 583 Answers
SOURCE: I have a 15 hp 2 stroke mercury outboard. When I
it is getting flooded ,dont ask me why, as im not there to check it out but if when first prmeing you stop pressing the bulb as soon as you feel any pressure at all, you will probably find it will start up straight away
Posted on Jan 17, 2010
agent91
  • 2100 Answers
SOURCE: how to clean boat carburetor
Carburetors are tricky, They have to be completely dismantled, soaked in carb cleaner, make sure all the gunk is off, every jet clean and clear, If you can't get a wire through it, you won't get gas through it, make sure you can blow through it, Get some guitar strings, .009 is about the smallest guitar string you will find, you can buy them separately at the music store if you don't have one. Change the filter in the line, when the carbs go back on, the adj all have to be the same, not one wide open and 2 idleing, Float level is also important, they don't sell complete kits anymore, you have to buy the parts individually, gaskets , etc, good luck.
Posted on Feb 14, 2010
  • 95 Answers
SOURCE: outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Posted on Mar 13, 2010
Mercury serial # 1B010234 what year is this motor?
Would have been helpful to know the horsepower. But here are charts you may be able to use to figure it out:
http://www.iboats.com/basics/mercury.html
MERCURY OUTBOARD MODEL YEAR GUIDE 15 25 HP Mastertech Marine
Aug 29, 2017 | Mercury Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
May I use higher octane unleaded fuel in this engine? (Say, 97 or 98 octane).
Hi Paul
Certainly you can. We use mid-grade or supreme in our Honda 15 outboard all the time. If the higher octane isn't needed, no harm done. After all, with a boat motor, it's working hard all the time and the higher octane certainly can't hurt.
Hope this helps.
-Steve
May 16, 2015 | Clymer Mercury/Mariner 4-90 HP Four Stroke...
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
45 hp mercury mariner outboard motor wont go into neutral or reverse is stuck in forward drive when started
will probably need a manual on your motor for this problem. perhaps careful disassembly will reveal the problem.
Jun 03, 2014 | Boating
I have a 15 hp 2 stroke mercury outboard. When I prime the fuel bulb it takes ages for the motor to start .If I disconnect the fuel lead a back pressure of fuel spurts back at the fuel connection to the...
Jan 16, 2010 | Boating
Boating Logo
62 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
