Question about Epson Stylus 1400 InkJet Photo Printer
Epson 1400 won't print blacks
Epson 1400 won't print black correctly. Especially notice in shadows, which print greenisk/reddish brown. Printer DID work correctly for a while on two different Vista OS.
  • johnsilverma Jun 14, 2009
    Tried 3 sets of brand new Epson brand ink - all same results.
    Epson replaced the printer... but the replacement printer still will not print blacks correctly.
    I also have a Canon Pixcma ip5000 connected to the same computer, printing the same file, using the same application (Microsoft Picture Manager) and it prints perfectly.
    Same bad results printing same file using Adobe Indesign or Photoshop from the Epson 1400.
    NOTE: Plugging the USB printer cable into any Vista OS computers and turning on the printer automatically installs the Epson 1400 print driver for that USB virtual port.
    Also used different USB cables - same bad results.
    Problem Solver:
  • 5 Answers
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Posted on Jun 14, 2009
  • andrewjamesb Jun 14, 2009
    Hi
    Thanks for your reply.
    In that case I would recommend using your other printer instead of the Epson 1400. In fact I have heard of several similar cases but involving different applications
    If you have had the printer replaced, can you specify that you require a different Epson model? Or if possible use Lexmark I recommend any Lexmark range for printing photos, letters etc
    You have tried for some time to fix this Epson issue I would try and exchange your Epson model for a different printer (say Lexmark)
    Hope this helps
    Thanks
    Andy
My epson black ink wont print??
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 10, 2012 | Epson Stylus Sx235w Inkjet Copy Print Scan...
My Epson 1400 is printing blacks green. After gray 40 % all my gray and black is coming out green. what can I do to solve that, and please don't tell me to chane my printer I just boughted it 4 months ago.
The printer is using your color cartridge to print black and greys.
The black cartridge must be empty and will need to be replaced.
The color cartridge has depleted one of the primary colors required
to print black.
Both cartridges will need to be replaced
Feb 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus Photo 1400 Prints Dark Shadows Red!
Did you use Epson Genuine Cartridges? ????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 15, 2010 | Epson Stylus Photo 1400 Printer
Epson 1400 Printing Orange colors Green
The problem can be two fold. Wrong cartridges, or blocked/damaged inkjet openings. Return it to the seller under warranty if its brand new. If it was fitted with non epson cartridges your warranty may be in question.
But I could almost guarantee the black qand the blue cartridges are faulty or their feed jets are
Jun 20, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson 1400 Printer Banding and color issues.
Try to print without high speed. If it's ok, you need to head alignment both black and colour.
May 26, 2009 | Epson Stylus Photo 1400 Printer
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
Communication error between Epson Printer and iMac
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Epson Stylus Photo 1400 Printer
Black and White photo printing problems on Epson 1400
Be sure your printer is not set on color. You will need the setting on black only for black and white.
Nov 22, 2017 | Office Equipment & Supplies
Epson 1400 wet black blocks of ink output
When this happen it means that your Fuser assembly and printer interior has toner contamination and build up. You can replace your fuser or run some more test print. Usually, the printer corrects itself.
Jul 26, 2008 | Epson Stylus 1400 InkJet Photo Printer
PRINTING WRONG COLOURS
have you replaced the injects? and were they refills or originals? and are they in the correct slot?
Dec 04, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus  1400 InkJet Photo Printer Logo
1,090 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
