Question about Compaq Presario R3000 Notebook
My r3000 has a tempermental power supply. it
My r3000 has a tempermental power supply. it alternates between being plugged in and running of the battery, which no longer holds a decent charge. I have tried replacing the power cord but it keeps doing the same thing. The power cord jack seems to get hot very quickly as well. I don't know how to fix the problem
  • askjbrown Jun 14, 2009
    thanks i will look into this solution.
  • 1,271 Answers
Whatabout the lead that plugs into the laptop ? does the plug in the laptop move easily, with the lead in, Sounds like the actual plug in the laptop is breaking away, the solder around the connector. Sadly to fix that you will have to get it repaired for about £50 to £70, maybe more ?? please make sure the lead from power supply is not loose or a bad fitting.
Posted on Jun 14, 2009
The power supply cord does not charge or supply power to the laptop. I purchased a new power cord only to find out that it is an internal issue. What part do I need to replace the internal power supply?
in all likelyhood it's the connect that the power cord plugs into. the soldering often fails in that area. it needs to be resoldered to make a good connection
Mar 28, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
MY Sony CDX-R3000 will only play CD's. It will not allow me to adjust volume, skip songs, or play the radio
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
Oct 07, 2009 | Sony CDX-R3000 CD Player
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 laptop
if you cannot test the laptop with another power pack i'd say that the systemboard has to be replaced
Mar 21, 2009 | Compaq Presario R3000 Notebook
The power plug won't charge the battery which prevents the computer coming on
There was a recent class settlement agreed to by HP regarding these models. HP failed to notify a ton of its customers and I've contacted Scott Kamber regarding.. (We were consultants for the suit).. Weve repaired a ton of these and you are not alone. Did you buy the machine new and register w/HP? Just curious...
Ken
Aug 02, 2008 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
